Electrical issue possible bcm? - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 4th, 2014, 09:52 PM Thread Starter
If in doubt, flat out
Local Time: 09:01 AM
United Kingdom Female
Hi guys.
New to this forum, I have a cooper s on a 53, and the central locking doesn't seem to be working well. It works on the remote but the door pins don't pop up, the passenger one hasn't done it for a while but now the drivers doesn't pop up. I also came back to my car after work to find my sunroof open when I didn't touch it (maybe unrelated).... My pan roof as also struggled to close last year but some of the time works fine.....I'm thinking it's the body control module if it is I can get one on eBay for 65 quid but do they need re coding? Any thought people?
Thanks x
teamcoopers is offline
post #2 of 2 (permalink) Old Jul 4th, 2014, 11:05 PM
Local Time: 08:01 AM
Hi ya
If the door lock pins are not popping up it could be the door actuator or that there getting trapped on the trim,
I had a funny fault where they would machine gun then lock it was to do with who ever had the door trims off had bent the pins.
I would also look at you rear view mirror to, that's where the remote sensor is for your key fob they do fail
If you think your BCU is playing up do a reset on it first. disconnect the battery for 30 min
Neg the poss then to reconnect poss then neg the ECM and BCU can get cranky worth trying
If you think the BCU has had it contact these guys they will fix it and no coding required
If you buy from ebay you will need to take an image from yours and recode yours which will mean recoding and syncing the ews pluss keys ect
BBA reman. ABS, ecu's, throttle bodies, air mass meters, MFD and catalytic converters
Do you have a spare key fob to use for a while
Hope this helps
marque is offline
MCS Engine noise when cold CBCooper Second Generation Faults & Fixes 2349 Mar 30th, 2016 09:09 PM
2005 Cooper S Electrical Problems. Shaun R53 Works First Generation Faults & Fixes 4 Feb 18th, 2015 07:29 PM
Intermittent acceleration issue on CM S 2012 beaver MINI Countryman 2 Mar 20th, 2014 06:29 AM
R56 '09 MCS Possible Carbon Build-up Issue? BlueBomberRC83 Second Generation Faults & Fixes 2 Feb 25th, 2013 02:48 PM
Wiper blade issue snerkler General Discussion 11 Aug 2nd, 2012 08:30 PM
