R53 Sunroof - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 13th, 2014, 04:18 AM Thread Starter
Local Time: 05:20 PM
R53 Sunroof
I am looking for advise on my 2004 Mini. About a year ago my son installed an after market stereo in the car, and after that the sunroof quit working. Pretty sure the two are related, but can't be certain. Went through what I know as far as fuses and stuff. Fuzes all good, and all looks connected like it should. Any ideas?
Ryndom is offline
post #2 of 2 (permalink) Old Jul 13th, 2014, 03:01 PM
Local Time: 11:20 PM
Hi ya
Try a reset by disconnecting the battery for 30min.
the body control unit can be a bit temperamental and can be spiked easy if you did not disconnect the battery during the radio fit
Disconnect the battery neg then poss then to connect poss then neg
Give it a try hope it helps
marque is offline
Tags: , , ,
Mcs r53 2006 muzzyx First Generation MINI Cooper S 4 Feb 28th, 2014 05:50 PM
Replacing Blind On R53 Panoramic Sunroof JohnP First Generation Interior & Ice 0 Mar 26th, 2013 11:46 PM
R53 Sunroof AndreFaria First Generation MINI Exterior 2 Mar 19th, 2013 09:23 AM
R56 Sticky sunroof when car is stationary. BMW says replace!? Aboutstu General Discussion 5 Jan 30th, 2013 07:50 PM
