Equalizing air to fuel - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 15th, 2014, 09:50 PM Thread Starter
Local Time: 06:51 AM
I just put on a cai and I am putting on a 17% pulley. Do I need to equalize my air to fuel ratio?
colbysnow8 is offline
post #2 of 2 (permalink) Old Jul 15th, 2014, 11:12 PM
Hi ya
do a ECM reset, disconnect the battery neg then poss leave it for 30 min then poss and then neg to reconnect.
This will reset the ECM and start it learning, it will adapt to the new mods
If you have a reduced sc pulley remember to change the heat range on your spark plugs you will need to go up a heat range to a 7 or 8.
once you have fitted new ones alway check them after a few heat cycles and every so often they do come loose.
I would also advise you to change the intercooler if you have not all ready,or in hot weather you may trash your engine.
It's always worth getting it on a dyno to check the air fuel ratio to be 100% safe
Enjoy
marque is offline
Water Pump & Air Conditioning Problems Atomic8001 Second Generation Faults & Fixes 4 Oct 1st, 2015 01:26 AM
Pathetic Fuel Consumption....Do something about it! steeve MINI Countryman 52 Apr 29th, 2015 02:51 AM
Forte fuel system cleaner Anyone recommend it ? / used it Ellies Mini Maintenance & MINI Care 5 Jan 18th, 2015 11:36 PM
high pressure fuel pump leak and head office lies! Shanos General Discussion 0 Nov 29th, 2013 05:24 PM
mini one - heating issues laurabond2002 First Generation MINI One 4 Jan 20th, 2013 01:53 PM
