Quickly Cooling Issue - MINI Cooper Forum
post #1 of 1 (permalink) Old Aug 10th, 2014, 08:05 PM Thread Starter
Local Time: 09:18 PM
My mates JCW spat it's water out today. I pressure tested the system as the expansion tanks tend to crack. It held the pressure for over half hour, cold and warm. Tried to bleed the system then and removed the bleed screw to find there is no water in the hose!!!
Am I right in thinking to change the thermostat first to see if that's stuck closed?
RikPowell is offline
MCS Engine noise when cold CBCooper Second Generation Faults & Fixes 2349 Mar 30th, 2016 09:09 PM
Cooling - Not a problem edirty6 General Discussion 9 May 16th, 2014 11:55 AM
Intermittent acceleration issue on CM S 2012 beaver MINI Countryman 2 Mar 20th, 2014 06:29 AM
R56 '09 MCS Possible Carbon Build-up Issue? BlueBomberRC83 Second Generation Faults & Fixes 2 Feb 25th, 2013 02:48 PM
Wiper blade issue snerkler General Discussion 11 Aug 2nd, 2012 08:30 PM
