Map sensor unplug - MINI Cooper Forum
post #1 of 2 (permalink) Old Aug 23rd, 2014, 10:21 PM Thread Starter
Local Time: 10:51 AM
Map sensor unplug
Hi all,
Can someone let me know if disconnecting the battery before disconnecting and reconnecting a map sensor will prevent engine warning lights coming up on the dash?
Karl
karlos9191 is offline
post #2 of 2 (permalink) Old Aug 26th, 2014, 11:52 AM
Local Time: 11:51 AM
Quoted: 1 Post(s)
map
Originally Posted by karlos9191 View Post
Hi all,
Karl
hi karl,as im having probs with my map sensor (p1237)i just had a check in my haynes and it does not say anything about discon the batt,but it does say make sure the ign is off before unclipping plug and also if you remove make sure you replace the seal,hmmm i did not replace my seal so maybe thats why i had the fault code above come up on my scanner??hope it helps...
rob955triumph is offline
Re map ecu petros88 General Discussion 4 Jan 10th, 2014 06:21 AM
Navigation - Map & Display questions npound Second Generation Interior & Ice 2 Dec 6th, 2012 11:53 AM
Map or maf sensor morgi27 Maintenance & MINI Care 5 Oct 7th, 2012 04:49 PM
Map cleaner morgi27 Maintenance & MINI Care 0 Sep 12th, 2012 12:04 PM
