matrix?? - MINI Cooper Forum
post #1 of 2 (permalink) Old Aug 26th, 2014, 10:28 AM Thread Starter
Local Time: 08:11 PM
Quoted: 1 Post(s)
matrix??
hi guys,i still have no heat in my 53 plate coop s,i have just taken off the plastic cover in the passenger footwell to have a look at the matrix to feel if it is cold..ie blocked,which it wasnt,its nice and hot??...now i did get a lot of brown water out of my rad when i took it off to do the s/c oil.....so i was thinking of changing my rad and matrix in case they were totally blocked,but if the matrix is getting hot,it cannot be blocked??..right or wrong??..also someone suggested it could be the control flap getting stuck??..where is that???..can anyone help please...winter wont be long and i will be needing some heat??
rob955triumph is offline
post #2 of 2 (permalink) Old Sep 21st, 2015, 08:25 AM
Hi,
Did you ever get this problem sorted? I have a 2002 MCS with the exact same problem, no heat from he blowers but the matrix pipes are red hot.
Really confusing me now this.
Amos is offline
heater matrix - swapout hints and tips baloo247 First Generation Faults & Fixes 3 Apr 22nd, 2016 12:25 PM
Heater matrix pipes Squires First Generation Faults & Fixes 1 Jan 22nd, 2014 11:30 PM
