Shift Light - MINI Cooper Forum
post #1 of 1 (permalink) Old Aug 26th, 2014, 10:34 AM Thread Starter
Local Time: 10:39 PM
Australia
Shift Light
I am thinking about installing a Shift Light however I would like to use a single led incorporated into the speedometer and using the cruise control icon as the shift indicator. The plan so far is to add the shift led into the housing along with the standard cruise control led, the shift led wires would then run to a standard Shift Light module.
I am not a fan of big obvious Shift Lights and thought this would be a good alternative.
This would be an RPM only shift indication ie the engine rpm = 6000 (or whatever is set) and the led lights up.
My mini is a 2006 R50 Cooper S "Park Lane" - with a large tacho in the dash and a small speedometer on the steering column, this mod will be attempted sometime in the future as I have only had the car a couple of weeks.
Caxack is offline
Brake light staying on shazab_rafiq First Generation Faults & Fixes 6 Dec 3rd, 2015 08:06 PM
Rear Fog light problem Dermottdog Second Generation MINI Exterior 2 Feb 13th, 2015 06:05 PM
Very annoying brake warning light issue! Kerinsey Maintenance & MINI Care 0 Feb 23rd, 2014 03:10 PM
Mini headlight / side light issue(i think) help caball Second Generation Faults & Fixes 1 Jan 25th, 2014 05:06 PM
Automatic gear shift "P" light stays on? MyFirst MINI Welcome New Members 0 Dec 15th, 2013 12:25 AM
