Heel and Toe? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 31st, 2003, 02:25 PM
Send a message via AIM to mikegre1
Local Time: 04:41 PM
Heel and Toe?
Just what is meant by "heel and toe", anyway?
Old Jan 31st, 2003, 02:32 PM
minicoopersgirl's Avatar
Loves MINI2
Send a message via Yahoo to minicoopersgirl
Local Time: 06:41 PM
United States Female View minicoopersgirl's Dark Silver & Black 1st Gen MINI Cooper S Profile
Lightbulb
Do a little reading....
http://www.turnfast.com/tech_driving..._heeltoe.lasso
PS - This is easy to do in the MINI!
Old Jan 31st, 2003, 02:57 PM
paulmon's Avatar
MINI2 Senior Derelict
Send a message via MSN to paulmon
Canada View paulmon's Dark Silver & Black 1st Gen MINI Cooper S Profile
Re: Heel and Toe?
MiniCooperSGirl has posted the perfect link; however, in the MINI I've found that using the left edge of your right foot is easier than using the actual heel. That website shows the driver rotating their foot more than is needed. In fact rotating the foot isn't needed just slide the foot to the right a little with a little twist and you should be able to touch the gas pedal. With a little practice twisting your foot you'll get the hang of it. The pedals are so close in the MINI that this is a breeze to master in the MINI.
Oh, I'd practice this in a safe environment it can be very tricky at first, nothing worse than braking, bliping the throttle and then your foot slips from the brake and BANG! Be careful and have fun.
Nothing beats coming into a corner, braking, downshifting and matching the revs perfect for the corner.
Paul
Old Jan 31st, 2003, 05:25 PM
Local Time: 05:41 PM
Canada View P.Phresh's Classified Ads
Somerthing I posted on another thread
When you're "blipping", you are "blipping" the throttle. During a downshift, especially coming into a corner, you're pushing in the clutch and your right foot will be pressing the brake, and at the same time with the side of your foot you will quickly pressand depress the gas pedal to get your revs up. This will enable a smooth downshift so your car remains balanced in the turn and then you can proceed to power out of a turn. If you are downshifting without this "blipping" of the throttle your car can become very erratic during the turn and can be dangerous, causing spin outs or oversteer. A good example to practice this in is during a yield. As you're approaching the yeild, you'll be travelling in 5th or 6th gear. At the beginning of your turn you will brake, then clutch, then begin shifting into 3rd. During the shift you "blip" the throttle, or quickly tap the gas pedal to bring your revs up so your car doesn't lurch forward or slow itself down with engine braking. Then finish your shift into 3rd and release the clutch while trail breaking into the turn. By the apex of the turn you should be able to power right out of it. All this should happen in a heartbeat, quick and smooth is the key. The shift into 3rd should be seamless, one smooth movement with little time spent in neutral.
Does any of that make sense?
If anyone likes I can explain double clutching aswell.
DS/DS MCS Premium & Sport Packages, Sun Roof, FK lowering springs, 18" Breyton Magic Sport, MOMO race aluminum shift knob
Old Feb 1st, 2003, 11:50 AM
So what's the difference between double clutching and heel and toeing?
Old Feb 1st, 2003, 12:10 PM
Keith's Avatar
Local Time: 10:41 PM
I also find the side of the foot works better than the heel. I am not sure whether to keep the heel on the floor or not. Having my heel on the floor limits the amount of throttle movement in the "blip" but lifting the heel reduces the amount of control I have making the whole process less smooth. What do others do?
2007 DS/W MCS LSD, sport suspension, Enkei RPM2 wheels
2002 EB/W MCS Sport package, Rogue intake, Borla exhaust, 15% pulley & Madness sway bar
Old Feb 1st, 2003, 12:17 PM
2nd Mini's Avatar
United States Male View 2nd Mini's Chili Red & White 1st Gen MINI Cooper S Profile
Double clutching is the practice of pushing in and letting out the clutch twice: pushing in once take the car out of gear, letting out to bring the intermediate transmission shafts up to the speed they would need to be at in order to allow smooth shifting into the new gear, then pushing in a second time to put the trans into gear and letting out to apply the gear. These days, the synchronizers do that for you.
2
"Go not to the elves for counsel for they will say both no and yes." JRR Tolkien
Old Feb 1st, 2003, 05:04 PM
paulmon's Avatar
I leave my heal on the floor, as you have said without your heal on the floor their is a lack of control and balance. Try rotating your ankle, that's all I do.
Paul
Old Feb 1st, 2003, 07:13 PM
When I heel toe, I'll keep my heel on the floor. The pedals are close enough and at the same level, when the brake is applied, that you don't have to twist your leg, and that's a good thing that's been designed about the MINI, they obviously had the driver in mind when they designed the pedal layout. When I apply the brake, I'll have the left half of my foot on the brake, then the right half of my foot will be on the throttle. To blip the throttle I pivot my foot so it presses down on the throttle a bit for just a quick sec. The pivot point/axis being the line that goes down the center of my foot, from toe to heel, which also is where the end of my brake pedal is. "Heel toe"ing has become second nature to me now, I do it without even thinking about it. Once you've been practicing it consciously it'll be very simple to do unconsciously. You'll have a hard time trying NOT to do it. A bit of a warning though, "heel toe"ing will lower you MPG, because your engine will have that extra blip of the throttle.
DOUBLE CLUTCHING
The sole purpose of double clutching is to keep your revs up while doing a downshift. It's mutch faster and better for your clutch. It's faster because when you are normally downshifting you will have to let the clutch up slowly and cuases more wear on your clutch also this method slows you down. Double clutching will allow you to have faster acceleration while already travelling at moderate to higher speeds. The benefit of double clutching is that you won't slow your car down, but you'll be in a lower gear to get that extra acceleration because your car will be in its power band.
Scenario:
You're travelling down a two lane street, with oncoming traffic in the opposite lane, moving at approximately 80 km/h and you're in 5th gear. You get stuck behind a slow moving vehicle travelling at 60km/h. You need to get around this guy and you're now driving behind him at 60 km/h and you're still in 5th gear. You see the opposite lane has traffic approaching but you can make it around the slow car if you move fast. Also there is traffic building up behind you and is right on your bumper. You will have to double clutch to get into a lower gear, for better acceleration, without slowing your car down at all. Then you'll be able to move around him.
So you'll be travelling at 60km/h in 5th gear now, with your RPMs reading at about 2 (x1000). To double clutch you will press the clutch in, then you will shift into neutral, and release the clutch. Your RPMs still reading 2 you will press down on the gas, called blipping the throttle, to bring your RPMs up to about 3. You can press the throttle all the way down to the floor, just stomp on it, just don't leave the throttle pressed down. Just push down to the floor then release right away. With your RPMs reading 3 you're ready to downshift into a lower gear, you will engage the clutch again, shift into 3rd gear, and release the clutch. Once you've released the clutch you shouldn't feel the car make any sudden jolts. All you will hear is the engine working at a higher RPM. If the car jolts suddenly, you have rev matched incorrectly. If your car throws you forward out of your seat, then your RPMs were too low. If your car pushes you into your seat or you chirp the tires, then your RPMs were too high. If you've done it correctly and everything is smooth you should still be travelling at 60 km/h and now in 3rd gear with your RPMs reading 3. Now just give it gas and pass the slow civic... er... I mean vehicle.
All these movements should be quick and smooth. From the beginning of the motion, the engaging of the clutch, to the end of the process, releasing the clutch, it should only take 1 second, and 2 seconds at most.
To practice this you can try it on a long, straight, empty road. Try going from 6th gear to 4th gear, or 5th to 4th. Try it at low speeds, the lower gear you pick, the higher RPMs you'll need.
Double Clutching at a glance:
-engage clutch
-shift to neutral
-release clutch
-blip the throttle
-engage clutch
-shift to lower gear
-release clutch
and that's why it's called double clutching, you engage the clutch twice.
tip: If you want to make it faster you can begin the next motion before the previous motion ends. ie, begin shifting before your clutch is completely pressed to the floor.
Old Feb 1st, 2003, 09:14 PM
Logan5's Avatar
Local Time: 03:41 PM
United States View Logan5's Cosmos Black & White 1st Gen MINI Cooper Profile
Years of driving air cooled VWs will cure you of having to keep your heel on the floor of the car. In the old VWs, the pedals are floor mounted, making it VERY difficult to keep the heel on the floor for anything. I have to say, though, that I've never tried to heel and toe my Karmann!
I'm practicing diligently, but I'm still not sure if I'm doing it right. I tend to brake to hard as I concentrate on getting over to blip the throttle... damn heel and toe!
Old Feb 2nd, 2003, 01:13 AM
Keith's Avatar
I don't think I agree with P.Phresh on double-clutching. You can match the revs perfectly with heel & toeing so you can let the clutch out quickly. As 2nd Mini said, double-clutching is all about matching the speed of the internal shaft in the gearbox. I can't see a need when the synchromesh works and it has to be slower to double-clutch than single-clutch.
Old Feb 2nd, 2003, 03:00 AM
paulmon's Avatar
I completely agree Keith, with a synchromesh gear box double clutching is pointless. However without synchro it's essential.
Paul
Old Feb 2nd, 2003, 03:24 AM
Local Time: 02:41 PM
Double clutching with a syncro garbox is NOT pointless!!! Unless you like paying for transmission rebuilds and new clutches.
Double clutching will extend the life of the syncros and the clutch many times. No wear occurs with a good double clutch, and wear occurs everytime with a mashed in downshift.
Double clutching well and driving smoothly should allow the clutch and syncros to last as long as the engine does. I come from a family of smooth double-clutchers, and no one has ever worn out a clutch.
Go ahead and just mash it into a lower gear and pay dearly for it later (and sound like you can't drive).
...And why do people downshift when slowing to stop? -- just use the brakes! Nothing sounds more amateur (and wasteful)
Here's to small cars
Old Feb 2nd, 2003, 03:31 AM
swamos's Avatar
MINI Traitor
Send a message via Skype™ to swamos
Local Time: 08:41 AM
Australia View swamos's Electric Blue & White 1st Gen MINI Cooper S Profile
Paul
It is definately easier on the syncros, which will last longer. It also sounds pretty good
It is a waste going up to lights, though
  #15 (permalink)
Old Feb 2nd, 2003, 03:42 AM
paulmon's Avatar
I was talking from a performace point of view not on the longevity of my tranny. If I wanted the tranny to live for ever and drive like a grandma I wouldn't have bought an MCS.
As for downshifting when slowing to a stop, I agree it's pointless unless your purpose in life is to have a little more fun. I blip and downshift at just about every stop and heal and toe going into just about every corner. I downshift to the stop to assure that I'm in the correct gear for the correct speed that the car is traveling. The bliping takes any engine braking out of the picture. I agree that downshifting without the blip and letting the engine provide some braking is a no no. If I need to speed up, aka the light just went green I'm already in 2nd or 3rd and ready to go. I match revs to a point that my passengers heads don't look like a "bobble head." I bought an MCS to have fun, not to baby it so that it will be perfect in 20 years. What's the point if you're not having fun?
Paul
Heel and toe help wanted. edzmini Second Generation MINI Cooper S 21 Aug 4th, 2007 06:51 PM
Heel and toe problem Hubert First Generation MINI Tuning 23 Sep 30th, 2003 05:13 PM
Favorite pedals for heel toe action??? DJcooper First Generation Interior & Ice 2 Jun 25th, 2003 01:26 PM
Exercises for your heel and toe rei00 General Discussion 3 May 24th, 2003 07:23 PM
Heel & Toe scollins First Generation MINI Cooper 13 Feb 25th, 2002 08:16 AM
