I need help to locate the MAF Sensor on my Mini One 2002. I removed the air filter box but still can't see the sensor. Pictures would be very helpful too
Hi
Do you mean the MAP sensor as I don't believe the one's had a MAF (I'm open to that argument tho !)
If you follow the air intake trunking from the air box to the throttle assembly you will see the sensor (MAP) just behind the throttle valve' it has a single 4 wire connector and held in by torx screws
I will see if I can get a pic but with the intake out of the way it is easy to see,
Cleaned it....didn't help. Strange is i'm getting no warning lights on dash. REV counter idle moves slightly down and then back up again. Engine doesn't stall though.
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
