Old Apr 12th, 2003, 05:40 PM   #1
KenL
KenL's Avatar
Local Time: 01:55 AM
Question MINI Chrome Handbrake Grip.
Hi All,
I've just purchased the MINI Chrome (well looks more like brushed alloy really) handbrake grip.
Anyone have any info on how to safely remove the old one and fit the new one? The tricky bit looks to be to remove the plastic gator bit from the existing knob.
Any advice would be most welcome.
Thanks,
KenL
Old Apr 12th, 2003, 06:01 PM   #2 (permalink)
monsta
MINI2 Global Moderator
monsta's Avatar
Local Time: 02:55 AM
Take the end bit off and there are a couple of clips which need to be lifted away from the handbrake itself so that the cover can slide off. The gaitor is held on with a small cable tie which isn't done up tight and you can just about edge it off the existing handbrake handle.
Reverse procedure to refit.
It's hard to explain, but once you attempt if you'll see what I mean
the MINI has gone...
United Kingdom View monsta's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Apr 13th, 2003, 03:04 AM   #3 (permalink)
KenL
KenL's Avatar
Cool
Monsta,
Thanks for your help. I tried and failed as I couldn't get the old one off. I managed to ease the gator bit off which as you say is held on with a cable tie.
Could you please explain how to/where are the
"couple of clips which need to be lifted away from the handbrake itself so that the cover can slide off"
I've attached three pics of the new grip. The first 2 are of the rear end and the third is the bit at the front.
Should the little bit at the back stay attached to the chrome bit or should they separate when trying to get it off?
Thanks,
KenL
ps anyone else want to chip in please feel free.
Old Apr 13th, 2003, 03:05 AM   #4 (permalink)
KenL
KenL's Avatar
pic 2
Old Apr 13th, 2003, 03:06 AM   #5 (permalink)
KenL
KenL's Avatar
Pic 3 the front bit.
Old Apr 13th, 2003, 03:36 AM   #6 (permalink)
monsta
monsta's Avatar
After looking at my old handgrip, it seems there is only one clip at the front.
I took a picture of it to show you want I mean.
Arrow 1 points to the bit you need to lift up (use a small screwdriver) it will just look like a bit of plastic from the top.
Arrow 2 shows the bit that clips down into the shaft. i.e. you need to lift it so that it clears the handbrake shaft.
The whole thing should then slide forward.
Yes take the end bit off first
Old Apr 13th, 2003, 04:20 AM   #7 (permalink)
KenL
KenL's Avatar
OK Monsta - got ya
Should be able to manage that.
Obvious when you know how
Many thanks for your help.
KenL
Old Apr 13th, 2003, 05:51 AM   #8 (permalink)
Dark Silver S
Ultimate Stealth Machine
Dark Silver S's Avatar
Local Time: 07:55 PM
Monsta, nice pics - very helpful!
Dark Silver S
http://revorg.org/images/mmg.gif
Now in Wilkes County NC
Old Apr 13th, 2003, 03:44 PM   #9 (permalink)
Minty
Man in the know!
Minty's Avatar
Send a message via MSN to Minty
im waiting for the AC Schnitzer Handbrake and Knob ...not long now
MINI-3 @ Cotswold MINI | BMW-four @ Cotswold BMW | E-Mail Me | Minty - Part of the IT Crowd!
Old Apr 13th, 2003, 06:26 PM   #10 (permalink)
KenL
KenL's Avatar
Thanks to Monsta's instructions I've fitted the handbrake.
Managed to get the new one on OK but the cable clip that retains the gator at the back was done up too tight to get it over the new handbrake without risking ripping the material. I've just re-positioned the gator and it sits nicely. Might have a go at fitting another cable tie although it's fine for now.
I'm very happy with the look and feel of it. Chrome may be nicer but the brushed look fits in well with the colour of the bright silver trim bits in the car.
Cheers,
KenL.
Old May 10th, 2003, 07:15 AM   #11 (permalink)
molly2003
molly2003's Avatar
Local Time: 08:55 PM
Thanks to your instructions, I was able to put on the Brake Handle/Grip.
Thank you.
However, my experience was a little different.
I was able to remove the front "cap".
However, in my hand brake there were actually 3 clips at the front, not one. One clip was by itself and the other two were on the opposite side, next to one another.
They were a bit tough to remove, though I was being careful not to damage them in case I needed to "chicken out" and put them back.
However, the problem I had most was with:
"The gaitor is held on with a small cable tie which isn't done up tight and you can just about edge it off the existing handbrake handle."
I couldn't edge it off. So, I was a bit creative and was able to see the cable tie and cut it off altogether.
Then when I was done putting the new chrome one on I ran a new cable tie and tucked it neatly back into place
Thank you for your help.
Tommy
Molly2003
Chrome handbrake grip MarkW19 Interior & Ice 5 Jul 4th, 2006 10:45 AM
New Posh Mini (GTuning) Handbrake Grip ! roland2003 GT Tuning 10 Nov 9th, 2005 09:52 AM
Handbrake grip??? MarkW19 Interior & Ice 3 Aug 14th, 2003 02:29 PM
