| It's just the steel grating causing more tramlining than usual. The steel ridges in the direction of travel are seldom perfectly aligned, and they drop into the grooves of your tires, causing the unpleasant wandering feel as they push your car sideways. I would expect the Dunlops to not do it as bad, as those tires don't have as many circumferential grooves. I wonder why the effect doesn't cause the DSC to freak out? After all, the steering wheel is staying straight, but the car is moving back & forth. Chip H. ex-MINI Cooper S owner and all around good-guy |
| I've driven the high rise bridge, but I think the bridge to the downtown tunnel on 264 is also very exciting! The wheelbase is similar on my Beetle, and both act about the same. The MINI has just a bit more drift. |
| Definitely the run-flats. Definitely definitely... I hit one in CT coming back from New York and thought I was going to die, the car was wriggling so much. I changed tires (yokos) and went back the next weekend.. same bridge, same conditions weather-wise, WORLD of difference. No wiggle, just grins! ~Rachel |
| MCS Wheel Alignment in Sydney - a question | mmilgrom | Australia | 7 | Oct 25th, 2007 05:18 AM |
| Rear wheel alignment question | Francesco | Wheels, Tyres & Brakes | 1 | Jul 22nd, 2005 09:33 AM |
| alignment question | daz23 | First Generation Faults & Fixes | 0 | Sep 24th, 2004 07:06 AM |
| Question about door alignment | scooterboy | First Generation MINI Exterior | 10 | Sep 8th, 2003 07:31 PM |
| Alignment question for Cooper S | ficcion | First Generation MINI Cooper S | 13 | Jun 26th, 2002 06:26 PM |
