Mini Pirate
Old May 6th, 2003, 01:00 PM   #1
GTmini
GTmini's Avatar
Local Time: 04:20 PM
Stiff Susp + Bump + Foot on Clutch
Has anyone else had some semi-embarassing moments due to this combination? Hope I'm not the only one. I was shifting into third on the way home tonight (in my MCS on 17s w/ Pirelli RFs) and hit a bump, which caused my foot to raise partially off the clutch in perfect timing to cause a lovely heart-stopping gear grind. ...also this was while right next to a BMW 3-series I was behind most of the way home. That was definitely a bit embarassing! Reminded me of a few lesser incidents I've had with releasing the clutch a bit quicker than intended on bumpy pavement.
Funniest coincidence too, b/c today I just made an appointment w/ my dealer to check out my gearbox next week due to some problems...hopefully that incident left no signs of abuse.
United States View GTmini's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 6th, 2003, 02:09 PM   #2 (permalink)
KenL
KenL's Avatar
Local Time: 12:20 AM
Re: Stiff Susp + Bump + Foot on Clutch
Originally posted by GTmini
[b]Has anyone else had some semi-embarassing moments due to this combination? Hope I'm not the only one..............................................
No, just you
Old May 7th, 2003, 01:46 PM   #3 (permalink)
GTmini
GTmini's Avatar
easier said than done with this car sometimes! Especially coming out of 1st...the engine really likes to hang onto its revs! A smooth 1st-2nd shift at anything more than a gentle start is still somewhat of a daily challenge.
guess I'm the only sucker with a truly bad timing experience so far though
Old May 7th, 2003, 06:10 PM   #4 (permalink)
mikeoconnor1
Local Time: 06:20 PM
My car used to bounce pretty bad over the bumps. Did you adjust the tire pressure. Mine were about 8 psi too high. It helped.
I doubt the dealer will see any signs of the missed shift.
Mike
2003 MINI Cooper S Chili Red
2005 Jetta GLI
United States View mikeoconnor1's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 7th, 2003, 06:29 PM   #5 (permalink)
Martin L
MINI defector
Martin L's Avatar
That must have been some pretty huge bump to mess up your gear change
Sounds like you maybe sitting too far away from the clutch if you can't keep a decent presure on it
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Old May 7th, 2003, 09:59 PM   #6 (permalink)
GTmini
GTmini's Avatar
Well, I didn't have much pressure on it at that moment as I was transitioning from depressing the clutch to getting ready to re-engage it...the bump just sped it up quite a bit more than I planned for...it was perfect split-second bad timing. However, you do bring up a good point!
I've been struggling to find a good seating position since my MCS arrived a couple of weeks ago...seems like when I'm the "best" distance from the clutch, I'm too close to the accelerator pedal. So I kind of split the difference and have been changing it up every few days. I don't have to hyper-extend my leg to fully depress the clutch, but it is near the limit of where I'm able to do it comfortably.
Old May 8th, 2003, 03:20 AM   #7 (permalink)
johnny36
Local Time: 11:20 PM
Better an up-shift ...
... than a down-shift.
A friend launched his Golf into the back of a truck when his foot slipped of the clutch during a down-shift.
New Pics JCW Susp & Brakes pikersteve Wheels, Tyres & Brakes 11 Nov 1st, 2006 04:37 PM
foot getting stuck when using clutch teejay MINI Cooper S 9 Jan 3rd, 2005 01:40 PM
Is the sport susp plus/17" too stiff? shadrach MINI Cooper S 13 Apr 30th, 2003 01:09 AM
Steering shaft hits my foot on the clutch Cooper_Works Faults & Fixes 5 Apr 29th, 2002 08:26 PM
