Think Mini
Old May 13th, 2003, 07:13 PM   #1
Richard Crofts
THE STICK
Richard Crofts's Avatar
Local Time: 12:15 AM
Unhappy Quick question
There are a range of clear lenses and projection style lights etc for the MINI in all its varients. My question is this how hard is it to get the rear lamp clusters out and switch them for a clear lamp set from say minispares or sport or an aftermarket supplier? Same q for the side repeaters? BMW charge £220 for the rear lenses and £20 for side repeater and then fitting of £160!!!! This is surely a rip off!...The £60 is to fit clear side repeaters and the 90-100 to fit the rear clusters! There is no way it takes an hour to fit some side repeaters surely?! (thats presuming that BMW labour is around the 60 mark like most posh car manufacturers garages are) The same with the rears...surely not 1.5 hours?!
Am I right?
Old May 13th, 2003, 07:36 PM   #2 (permalink)
hurrens
hurrens's Avatar
Send a message via MSN to hurrens
United-Kingdom
Changing the side repeaters is simple. Put your hand down the side behind the repeater from under the bonnet and push out the tab closest to you. Push the new unit back in reverse. Ten minutes per side. The rear lights are a bit more complicated, especially the high-level rear light. See this link. This is the fitting guide from MINI.
I hope this helps.
Black Jack
Old May 13th, 2003, 07:37 PM   #3 (permalink)
hurrens
hurrens's Avatar
Sorry I missed the link off. http://www.minimania.com/images/Inst...Conversion.pdf
Here we go.
Black Jack
Old Jul 9th, 2003, 12:55 PM   #4 (permalink)
iaa
iaa's Avatar
Local Time: 01:15 AM
Rear lamp cluster replacement
My ONE was assaulted by a shopping trolley yesterday and now needs a replacement rear lamp assembly (£37 inc. VAT). Fortunately, the "driver" of said trolley was good enough to come into the store and have me paged and will be paying for the damage.
I'm happy to swap the lamp assembly myself and there is no other damage to paintwork etc., but was wondering if there are any pitfalls to avoid in fitting a rear lamp assembly?
Ian
England View iaa's Chili Red & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jul 9th, 2003, 12:59 PM   #5 (permalink)
mikeythemini
I can't get no sleep
mikeythemini's Avatar
Rear lamps take 10 mins to fit. 10mm nut
The high level brake light 5 mins on a S, although I have heard with some spoilers it is more difficult
mike
Old Aug 14th, 2003, 08:57 AM   #6 (permalink)
iaa
iaa's Avatar
mike
My replacement rear lamp assembly finally arrived and was actually cheaper than originally quoted - £35.40 vs. £37.
The 10 mm nut is a Nylock and so takes quite a long time to remove and replace with a standard spanner(wrench), but otherwise the removal and fitting was quite straightforward - though it took some significant pressure from the outside to engage the two metal spring clips.
Ian
Old Aug 14th, 2003, 10:57 AM   #7 (permalink)
euan
euan's Avatar
Send a message via AIM to euan
When I picked up my clear side repeaters, the dealer fitted them for me, free of charge....
Gone - IB/W Cooper, bonnet stripes, white indicators, Chili
Now - EB/W S, stripes, Chili, climate, R90's :-)
Scotland View euan's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
A Quick Hello And A Question Charlie Cooper General Discussion 4 Apr 29th, 2006 11:52 PM
Really quick question... jdr21 General Discussion 4 Apr 18th, 2006 08:11 PM
Quick question. jdr21 General Discussion 1 Oct 6th, 2005 05:30 AM
Quick question, quick answer ChrisBuer Wheels, Tyres & Brakes 9 Jun 14th, 2005 01:51 AM
Quick question James Haigh MINI Cooper S 7 Apr 19th, 2003 09:56 AM
