Rear Wiper on Intermittent Problem - MINI Cooper Forum
post #1 of 6 (permalink) Old Jan 9th, 2017, 10:59 PM Thread Starter
Local Time: 03:41 AM
Quoted: 28 Post(s)
Been using the rear on intermittent all the time recently. Today I noticed it was stopping mid sweep - not returning to park position between wipes. Turn off and on and parks fine. Works for a while on intermittent, then does it again.
Also, when sweeping, getting interference on radio (on FM). Electrical gremlin? Not working freely? Motor giving up?
2005 R53.
Any thoughts.
NigelK is offline
post #2 of 6 (permalink) Old Jan 9th, 2017, 11:12 PM
Quoted: 701 Post(s)
The wiper motor is probably starting to die Nigel but fortunately you will have the Valeo unit fitted so its the cheaper one out of the 2. Before spending any money undo the rear panel (about half a dozen torx screws from memory) then give the multiplug terminals a clean and see if this helps. The early motors were Trico units and were prone to this so I converted my R50 to the later type and never had a problem since
You can pick up a brand new one for 50 delivered from minitech and they are easy to fit!
SeanC is offline
post #3 of 6 (permalink) Old Jan 10th, 2017, 01:38 PM Thread Starter
Quoted: 28 Post(s)
Thanks Sean. And for the link.
Car has done 98,000 miles so motor might be getting a bit tired.
Is the hatch rear inner panel held on with torx screws rather than clips (which always seem to snap)? I'll get at it and give the multiplug a clean. I think I need a Haynes manual.
My 'new best friend' Mini breaker round the corner has probably got one. The 3 cars he's got at the moment are R53 pre-facelifts, all quite low mileage. Does that mean they'll likely have Trico rather than Valeo units, the better later one?
NigelK is offline
post #4 of 6 (permalink) Old Jan 10th, 2017, 03:52 PM
Quoted: 701 Post(s)
If its a pre facelift then there's a very good chance they will have the Trico motors . Valeo motors have the upgraded arm and washer jet as pictured so if the cars don't look like this then they have the Trico's fitted
Hope this helps
Name:	2017-01-10 15.43.22.jpg
ID:	209834   Click image for larger version
Name:	2017-01-10 15.43.58.jpg
SeanC is offline
post #5 of 6 (permalink) Old Jan 11th, 2017, 03:55 PM Thread Starter
Quoted: 28 Post(s)
Thanks Sean. Mine look like this, same as yours, Valeo.
The other question. Is the hatch inner panel just held on with the Torx? No clips?
Name:	Small NK 01.JPG
ID:	209882   Click image for larger version
Name:	Small NK 02.JPG
NigelK is offline
post #6 of 6 (permalink) Old Jan 11th, 2017, 09:04 PM
Quoted: 701 Post(s)
Its held on with torx screws from memory Nigel. Its easy peasy to remove
SeanC is offline
Rear wiper motor stem problem ScreamMini First Generation Faults & Fixes 4 Oct 23rd, 2014 02:34 PM
Rear Wiper Issues PatentToast Second Generation Faults & Fixes 0 Mar 10th, 2014 08:37 PM
Intermittent sound problem with IPOD and AUX inputs dsmith Second Generation Interior & Ice 3 Jan 22nd, 2014 09:30 AM
Different Wiper Intermittent Problem? nickt68 First Generation Faults & Fixes 0 Dec 22nd, 2013 12:56 PM
