Electric problem please Help - MINI Cooper Forum
post #1 of 7 (permalink) Old Feb 1st, 2017, 08:21 AM Thread Starter
Local Time: 05:23 AM
I replaced the clutch a week ago in my 05 mini, after leaving the garage all the lights began to blink and do not know what to do with it
Now the garage is saying its my problem
Gregorysk is offline
post #2 of 7 (permalink) Old Feb 1st, 2017, 09:00 AM
Local Time: 06:23 AM
Quoted: 858 Post(s)
Your not helping yourself by posting this 3 times in 3 different topics!
SeanC is offline
post #3 of 7 (permalink) Old Feb 1st, 2017, 09:09 AM Thread Starter
I'm sorry I don't even know how to delete the other two
post #4 of 7 (permalink) Old Feb 1st, 2017, 02:19 PM
Quoted: 858 Post(s)
A moderator will most likely delete them. Multiple posts on the same problem just causes confusion and is frowned upon. One problem- one topic.
SeanC is offline
post #5 of 7 (permalink) Old Feb 1st, 2017, 09:25 PM
Local Time: 03:23 PM
Quoted: 179 Post(s)
Australia Male
Garage
You replaced the clutch or you had a garage do the work ? If you have an issue with work done by a garage, write to them politely and explain the problem and try to resolve the issue. Keep a copy of all correspondence. If they fail to come to an agreement, contact consumer affairs and who ever the automotive repair governing body is. Check all electrical fittings are correctly plugged in and also check your earth points.
The key is being firm, pleasant and polite and keep a copy of all correspondence should you need to resort to consumer affairs as this goes in your favour should you need to go down that track.
Milpol is online now
post #6 of 7 (permalink) Old Feb 15th, 2017, 03:25 AM
Hey Hey
webbrowan's Avatar
Australia Male
If you did the replacement on your own, chances are that nobody is going to want to touch the car and even insurance companies may decline to help you with claims because of "tampering". But yeah, if the work is originally done by somebody, you should be able to get them to rectify what they created to begin with. Otherwise you should report them for bad customer service.
webbrowan is offline
post #7 of 7 (permalink) Old Mar 1st, 2017, 02:45 AM
Quoted: 2 Post(s)
ground problem ( earth point )
from the sounds of it they left at least one or more main ground connections off .
if i remember correctly there are several that go to the trans.
seh1 is offline
Electric power Streering wheel problem olayinka Second Generation MINI One 5 Jun 22nd, 2016 07:19 PM
Electric Fan problem camonixo First Generation MINI Cooper S 1 Apr 30th, 2015 09:25 PM
