Gearbox/ clutch - MINI Cooper Forum
 7Likes
post #1 of 16 (permalink) Old Mar 20th, 2017, 07:35 AM Thread Starter
Local Time: 08:59 PM
Quoted: 1 Post(s)
Gearbox/ clutch
Over the weekend I had an issue with the car 2004 cooper, I had trouble getting it in reverse, then eventually managed to get it in gear.
After around 5 minutes I put the car into 3rd and it bunny hopped made a lot of banging and stopped. It will only turn over with the clutch down. Any ideas on the cause and cost of repair?
DAC1984 is offline
post #2 of 16 (permalink) Old Mar 20th, 2017, 10:37 AM
Local Time: 06:59 AM
Quoted: 181 Post(s)
Australia Male
Garage
Sounds like you have a failed Midlands gear box, they mostly fail due to being thrashed and laboured in 5th gear which puts a lot of stress on the shaft and hence a failed bearing, also an adherence to the BMW filled for life policy which is garbage and should have a complete oil change every 50,000 km or 30,000 miles. If you live in the UK, you wont go past John Tee at this link, mini gearbox, gear fix - Mini recon gearboxes | BMW MINI cheap gearboxes .
The Midlands also has a large supply of parts available for replacement as long as there is no damage to the gearbox housing.
Cost will be dependant on you swapping the box out or paying some one to do it, also the cost of repairing the box, DIY or Pay to repair.
Again, if your in the UK call John Tee and have a chat, if your any where else, its anyone's guess.
John has an FB page at this link, https://www.facebook.com/Mini-Gearbo...4655564239946/
SeanC likes this.
Milpol is offline
post #3 of 16 (permalink) Old Mar 20th, 2017, 10:56 AM
Akkip's Avatar
Quoted: 13 Post(s)
Norway Male
First of, sorry to hear about the box failure, it's really sour when things like that happen.
Definitively sounds like a fatal gearbox failure, the only thing you can do now is have the gearbox removed and the unit inspected.
Not really sure if the bolt patterns are the same, but maybe you could look into a possible swap to the MCS GETRAG gearbox, it can take a lot more of a beating.
Hope it gets sorted
SeanC and Milpol like this.
Akkip is offline
post #4 of 16 (permalink) Old Mar 20th, 2017, 11:30 AM
Local Time: 09:59 PM
Quoted: 858 Post(s)
Getrag swap out is possible but you would also need hubs and drive shafts to match
Milpol likes this.
SeanC is offline
post #5 of 16 (permalink) Old Mar 20th, 2017, 11:58 AM
Quoted: 181 Post(s)
Australia Male
Garage
Also gear shift assembly, shift cables, clutch slave cylinder, clutch line segment (clutch line is in several parts) etc so consider the cost, John Tee also does the conversions.
SeanC likes this.
Milpol is offline
post #6 of 16 (permalink) Old Mar 20th, 2017, 12:39 PM
Akkip's Avatar
Quoted: 13 Post(s)
Norway Male
Speaking of gearboxes and a bit off topic (sorry)
Just saw a JCW Getrag 6spd pop up on eBay, listed as Limited slip, can anyone confirm that the JCW had that on the R53?
Akkip is offline
post #7 of 16 (permalink) Old Mar 20th, 2017, 10:52 PM
Quoted: 181 Post(s)
Australia Male
Garage
Cant see why not, I have one on my R53. There was a way of working out which GB had the LSD by one of the component stamps on the GB.
Will just pop out and look at my spare !
OK, had a look and there is a label with a bar code and some numbers which end in BKL and from memory that tells you if its got an LSD. I will however stand corrected but that is what I was advised.
Milpol is offline
The Following 2 Users Say Thank You to Milpol For This Useful Post:
post #8 of 16 (permalink) Old Mar 20th, 2017, 11:16 PM
Quoted: 181 Post(s)
Australia Male
Garage
OK, this thread had a ref to the type of boxes, http://www.mini2.com/forum/first-gen...eed-boxes.html
Ok,
The old 2002 type gearbox is GS6-85BG - TBKA
the new 2005 type gearbox is GS6-85BG - TBKE
And if your really lucky and it ends in TBKL it already has a diff on it. Not sure if you can see that anywhere on the box
Unquote:
Also see the image attached.
Milpol is offline
post #9 of 16 (permalink) Old Mar 20th, 2017, 11:41 PM
Akkip's Avatar
Quoted: 13 Post(s)
Norway Male
Thanks @Milpol , as always you are the wikipedia when it comes to obscure info!
Guess i'll just have to live without since the seller didn't really want to ship it here.
Shame really as i'm converting to a single mass lightened flywheel and stage 2 clutch, and having the diff thrown in at the same time would save a lot in labor costs ..
(Sidenote: Was just out minding my own business when what i presume was a Mk IV Golf 1.6 petrol pulled up alongside me wanting to race, needless to say he got parked hard)
Milpol likes this.
Akkip is offline
post #10 of 16 (permalink) Old Mar 21st, 2017, 12:19 AM
Quoted: 181 Post(s)
Australia Male
Garage
Cheers, from what I can gather, the Quaife is the better option for LSD but its not cheap
Milpol is offline
post #11 of 16 (permalink) Old Mar 21st, 2017, 12:27 AM
Akkip's Avatar
Quoted: 13 Post(s)
Norway Male
Been drooling over that one for a while, but it costs quite alot, not as much as the OsGaiken one which has (according to them) "True 100% locking capabilities".. But still.. it's quite the investment.
Milpol likes this.
Akkip is offline
post #12 of 16 (permalink) Old Mar 30th, 2017, 08:06 PM
Quoted: 1 Post(s)
What is needed to put the Getrag gearbox in a older 5sp mini?
M4rty is offline
post #13 of 16 (permalink) Old Mar 30th, 2017, 09:04 PM
Quoted: 858 Post(s)
A Gertag gearbox for starters
Drive shafts, hubs, gear linkage and selector and a clutch kit
SeanC is offline
post #14 of 16 (permalink) Old Apr 11th, 2017, 01:29 AM Thread Starter
Quoted: 1 Post(s)
Gearbox ended up being replaced along with the clutch.
That was three weeks agI and now the gears have started clunking and in 4th or 5th it has started making a whining/whirring sound as if it's struggling. Any ideas?
DAC1984 is offline
post #15 of 16 (permalink) Old Apr 11th, 2017, 03:32 AM
Quoted: 181 Post(s)
Australia Male
Garage
Was the gearbox a SH unit from a wreckers or was it a totally refurbished/rebuilt unit ? It doesn't sound healthy so I would stop driving it in case you damage the casing as this will render the whole unit useless for rebuilds or change overs. It will be a case of drop the box out, strip it down and inspect it.
Milpol is offline
The midlands/r65 gearbox issues minione2002 First Generation MINI Cooper 17 Nov 2nd, 2016 02:38 PM
The midlands/r65 gearbox common issues.. minione2002 First Generation MINI One 2 Oct 31st, 2016 12:24 PM
Midland Gearbox repair help jobforacowgirl First Generation Faults & Fixes 11 Sep 29th, 2015 04:11 PM
Clutch 2005 Mini Cooper S capacitytube First Generation Faults & Fixes 2 May 16th, 2014 03:50 PM
What RPM do you start 1st with? thewhitenight000 First Generation MINI Cooper 2 Aug 8th, 2012 06:19 AM
