Performance Torque
Old Jun 12th, 2003, 01:03 AM   #1
elmadi
Local Time: 08:03 PM
MCS or VW GTi 1.8T??
My cousin who both tested the MCS and the VW GTi 1.8T. He both like it. He told me performance and pricewise is close but the "practical" side---it seems the GTi got the edge like bigger rear space,full spare etc.
Though I have not experience the GTi, I tried to persuade him to get the MCS.
Any addtional suggestion out there???
Thanks.
(USA only)
United States View elmadi's Liquid Yellow & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 12th, 2003, 01:04 AM   #2 (permalink)
addman
addman's Avatar
Local Time: 03:03 AM
Residual value?
United Kingdom View addman's Black-Eye Purple & Body Color 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 12th, 2003, 01:10 AM   #3 (permalink)
LuckyRVA
1.6 Litres of fury!!!!
LuckyRVA's Avatar
Local Time: 10:03 PM
Send a message via AIM to LuckyRVA
Yeah, the GTi handles like a brick. Wallows in corners and what not, I think mainly due to the solid rear axle.
Also VW's build quality has been pretty shady here in the US as of late. Broken MAF sensors and window switches are pretty common. The coil packs also like to go bad.
I too was considering getting a GTi before I placed my order for my MCS, but my girlfriends Golf has had a bunch of electrical faults since she bought it 1 year ago.
I haven't had any problems that bad with my MCS(knocks on wood).
Also, when the seats are folded down there's not that much difference in space compaired to the GTi. I fit a 32" and a 27" tv in my car at the same time when I moved about 8 months ago.
Hope this helps!
Jason
2002 Dark Silver Cooper S w/ white roof. SOLD
Old Jun 12th, 2003, 01:11 AM   #4 (permalink)
dinger
TT or not TT
dinger's Avatar
Local Time: 02:03 AM
If your cousin needs a lot of loading space then it has to be the VW GTI 1.8T,but is he aware there's a new model golf due to be launched by the end of the year.
Old Jun 12th, 2003, 01:12 AM   #5 (permalink)
dinger
TT or not TT
dinger's Avatar
The NEW Audi A3 1.8T would be a better bet.
Old Jun 12th, 2003, 01:18 AM   #6 (permalink)
LuckyRVA
LuckyRVA's Avatar
We don't get that here unfortunetly.
Jason
Old Jun 12th, 2003, 01:21 AM   #7 (permalink)
BennyB
Well i'd choose the MCS for looks performance and the handling But on the pratical side it's not a golf. your a bit squashed getting 4 blokes in the car including the driver. Me and 3women there's plenty of room but if only that happend more often. But if you use it as i 2 seater i've actual found it very spacey as the front seats in the minis seem to go back really far and give you loads of leg room! The boot size is tiny with the back seats up but you can get a quite a bit in with them down. The main thing is that the golf is a 5 seater and minis are 4. Well good luck convincing him on the MCS, shouldn't need to much as they drive like dream to drive and look much more stylish then a golf.
Old Jun 12th, 2003, 01:23 AM   #8 (permalink)
dinger
TT or not TT
dinger's Avatar
Jason
Old Jun 12th, 2003, 01:58 AM   #9 (permalink)
SugarBelly
SugarBelly's Avatar
Local Time: 09:03 PM
1 IN a million? or 1 OF millions?
-dinger
A great suggestion!
We don't get that here unfortunetly. -LuckyRVA
=> We don't?! That's to bad, - it could really save Audi/VW's tush right about now!
More to the point, - elmadi...
1. You don't have to limit responses on this topic to "USA only" as europe & most regions have these two variant options & would offer you & your cuz superb info, especially regarding practicality, as the rest of the world knows how to make do with smaller vehicles, much better than most of americans.
2. How'd you get so many posts without learning MINIs are the best?!
3. I'm not going to research it, but what difference can there be between the 25.1 cubic feet of rear space offered by MINIs & that offered by the Golf? If space is a true concern here, he should be considering the Jetta Wagon. Better yet, for the same money, a few years older Passat Wagon would be better. Or a Subaru Outback, which I would expect to be pretty even keel on performance, mileage, handling, economy, upgradability, residual values, etc.
4. Be careful. There is nothing practical about buying the last model year. VW's big ad campaign for their special GTi, GLI builds or "Wolfsburg" versions is marketing aimed at nabbing those over-excited about the car's offerings.
The fact that their values will decrease significantly faster than all other similar model years (because a new model design is on the boat on its way over), gets lost on the faithful. Hence, their even bigger discounts for previous VW/Audi owners.
5. The fact that Audi/VW had to be taken to court and sued in order to "appreciate the fact" that their famous 1.8t engine Coil packs were causing problems, even evident safety risks, means the company(ies) have their priorities out-of-wack. Granted, they did end-up recalling over half a million cars, but do you still wanna be a part of that pool? Knowing if they had their druthers, they would've let it slip under the rug?! For-Get about it!! Neither VWs nor Audis have been applauded for this consumer treatment & their vehicles are not cheap.
6. Ok. That leaves you with the Full Spare issue.
===> Better to get the Golf.
-sb
Old Jun 12th, 2003, 02:48 AM   #10 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
Go for the MCS and this is why:
The Mini was designed with the intentions of being a real good and fun car to drive i.e wheels pushed right out in the corners, wide stance, low centre of gravity, stiff chassis etc.....
The Golf designed as a Ford Focus alternative, good space, comfy ride, basically small 'family' car features, then VW stuck on some bigger wheels, racaro seat's, stiffer suspension and a turbo and called it a GTI???
I know it's not a simple as this but it's like the Mini has been designed the way it is whereas the Golf is just an ordinary one with some bolt ons.
If your cousin wants a car like the Focus get the Focus ST170 (CAN PULL 1G CORNERING!!) supposed to be best in the class??
The Mini is classless it also sounds better when somebody asks you what car you have,
- A new Mini
wot a Cooper
- no a Cooper S!!
Japan Male   Reply With Quote
Old Jun 12th, 2003, 02:54 AM   #11 (permalink)
Andy@Ross-Tech.com
Andy@Ross-Tech.com's Avatar
Send a message via AIM to Andy@Ross-Tech.com
I had a GTI 1.8T and now have a MCS. After dumping $1500 in mods into each of them, here is the outcome:
The MINI flat out pulls away from the GTI in a straight line. In corners, it is nowhere near close. The only parts about the GTI that I miss are the seats (MUCH more comfortable and supportive than the MCS seats) and the cargo space. The MINI has about 1/3 the hatch space with the seats in place. The GTI can swallow 4 wheels/tires in the hatch with the seat in place. In the MINI, I popped out the rear seat and put the tires in its place:
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Jun 12th, 2003, 03:29 AM   #12 (permalink)
ipartridge
ipartridge's Avatar
i expect the VW sites will tell you Golf GTI every time, can't your 'cousin' make his own mind up?
United Kingdom View ipartridge's Solid Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 12th, 2003, 03:32 AM   #13 (permalink)
Darus
I have a 2000 VW GTI 1.8T and I am selling it to get myself an MCS, I can't wait!!!
My GTI had a lot of quality issues but I think a good amount of them have been fixed in the more recent models.
After test driving an MCS I think it is generally a more fun car to drive.
I can't wait to get my MC!! Yes I am obsessing over it!!
Old Jun 12th, 2003, 03:47 AM   #14 (permalink)
noopd
noopd's Avatar
Local Time: 06:03 PM
Send a message via ICQ to noopd
I used to drive a 1995 VW GTI VR6 and loved it. In terms of value, you can't beat the GTI. They pretty much have every convenient and comfort feature in the car as standard and they car drives well. I had no problem with it at all during my 7 years of ownership. Cargo space is awesome and you can move a lot of stuff with it. The 20th annerversary edition just came out, and the 177kW/241 hp R32 is due later this year. It will be one great car.
If you decided to get the GTI, make sure you get the manual one though cuz I dont' really trust VW's automatic transmission.
The A3 will be here in US next year.
Mini is also a great car as all of us here are very passionate about it. I havn't got mine yet (should be here in 2 more weeks).. so I can't say much about it. But from this site, the quality of build is an issue i think. the back seat space is another issue... but it will certainly be the car most fun to drive and handles the best.
I am a long time fan of the mini cooper, love the classic one. I sold my GTI to get a mini just because my GTI is getting a little old. It will be a tough choice to pick between these two cars if I have never drove a GTI before. I didn't want to get the same thing.
So, my recommandation is: get the GTI for the value and comfort. get the R32 if you want something powerful.. and get the Mini if you want something fun to drive, handles great, a classic design, and a bunch of people waving at you when u drive.
United States View noopd's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 12th, 2003, 03:48 AM   #15 (permalink)
Andy@Ross-Tech.com
Actually some VW sites are pro-MINI:
http://forums.vwvortex.com/zerothread?id=614443
Old Jun 12th, 2003, 08:40 PM   #16 (permalink)
sgrewal
Well I own a 2002 MCS and a MKII Golf GTi 16v - in that beautiful oak green with BBS alloys - trust me the new Golfs are nowhere near as good as the classless, classic MKII (and of course MKI) - many friends who once owned the MKII 1986-1991 or so(?) and then got the MKIII and MKIV - all say the same they are awful! The new MKV should be better though! MCS every time over a MKIV 1.8T!
Sukhjit- MINI NOW GONE - did have a 2002 MCS - Dark Silver / Black with Chili pack
Old Jun 12th, 2003, 08:44 PM   #17 (permalink)
Ginger
Lovin my iPod
Ginger's Avatar
MCS every time, besides the Golf is due to be replaced shortly.
G
Old Jun 12th, 2003, 08:59 PM   #18 (permalink)
Rakey
Four Candles?
Rakey's Avatar
Well the Golf GTi 1.8T, was one of the other cars that I test drove before ordering my MCS.
What put me off was the fact that the Turbo just did not have the beautiful noise of the Supercharger in the S, and the flat spot in the lower revs before it kicked in. Also the lack of good customer service stopped me from returning to VW, it felt like I was been looked down on just cause I was wearing shorts and T-shirt, my causal dress shouldn't mean I get treated any different to the guy in the shirt in showroom!
Oh the final decider, well if I had brought a golf no-one would have turned their head as I drove it, not like in the MCS, and the golf is the car that my mother would have chose, oh yes she does drive a golf.
Go on, get the Cooper S!!!!! It will put a smile on your face everytime you get in!
Old Jun 12th, 2003, 09:01 PM   #19 (permalink)
rusty
rusty's Avatar
For practicality it has to be the Golf, but for EVERYTHING else, it HAS to be the Mini
Chlli Red Cooper, White roof, 17" S Spoke, Chilli Pack , Chrome Vents, Personalised Plate + all other little extras inc CD Boost, Air Con, Heatad Mirrors, Traction Control.
United Kingdom View rusty's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
MCS vs Gti vs 130i titleist8 MINI Cooper S 42 Mar 22nd, 2006 04:07 PM
GTI R32 vs 05 MCS... Which to get? mlebeau General Discussion 25 Nov 5th, 2005 08:01 AM
VW GTI 1.8T vs. MCS benny MINI Cooper S 19 Jul 12th, 2003 05:45 PM
MCS vs Peugeot 205 GTI Kip MINI Cooper S 10 Sep 18th, 2002 11:11 AM
MCS vs GTI 1.8T -US Spec JMINI MINI Cooper S 35 Sep 15th, 2002 10:15 AM
