Visit Derek Woodman MINI
Old Jul 20th, 2003, 05:06 PM   #1
curryman77
Local Time: 01:20 AM
Blue Cooper Fitting Headlamp Covers
HI ANY ONE PUT A SET OF THE HEADLAMP COVERS ON YET IN THE INSTALLATION INSTRUCTIONS IT SAY TO MIX 1 PART ALCOHOL TO 3 PARTS WATER ANY HELP ON WHAT TO USE AS ALCOHOL THANKS
United Kingdom View curryman77's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 20th, 2003, 09:34 PM   #2 (permalink)
shkeller55
Local Time: 07:20 PM
I think the instructions that came with mine said to use rubbing alcohol (isopropyl alcohol). I haven't actually tried it yet though, as my car's still in the body shop getting damage the dealer did to it repaired. Once I get it back I'll put the headlight film on.
Scott in ATL.
2002 Mini Cooper S Chili Red/White.
1998 Mercedes ML320.
United States View shkeller55's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 20th, 2003, 10:24 PM   #3 (permalink)
Razor
MINI2 Scooterist
Razor's Avatar
Errrm Guinness?
United Kingdom View Razor's Solid Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 21st, 2003, 01:09 AM   #4 (permalink)
BruceK
Moderator & Sponsor
BruceK's Avatar
Local Time: 06:20 PM
I've installed the clear plastic headlight covers. Yes, as shkeller55 indicates, you must use rubbing alcohol (isopropyl alcohol) mixed with water - and use it liberally.
It is also important to follow the instructions and make sure your fingers are completely soaking wet with the solution when you touch the adhesive side (dry fingers leave permanent marks). The protectors are fairly easy to line up, and you can peel them back off and reposition it during the process it you need to. The squeegee part to make the plastic fit flush on the headlight went smoothly on my headlights. The whole process only took 5-10 minutes to install for both headlights.
It took about 4 days to a week for all the water fogging to disappear and for the lights to become crystal clear.
Headlamp covers MD1 MINI Convertible 2 Aug 2nd, 2004 09:49 AM
Installed Optical Blue headlamp covers today..pics dav Exterior 7 Feb 9th, 2004 04:42 PM
Optical blue headlamp covers dav Exterior 6 Feb 9th, 2004 02:48 AM
Headlamp problem - anyone had this before? Tonyt3 Faults & Fixes 12 Dec 28th, 2003 05:29 PM
