Number plate mounting (rear) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 30th, 2003, 07:42 PM
rhardaker's Avatar
Big Grin...
Send a message via MSN to rhardaker
Local Time: 08:10 PM
United Kingdom Male View rhardaker's Classified Ads
I am planning to stick on some new number plates (not screw them on - to get rid of the screw heads). The front is easy as there are just screw holes in the bumper. The back plate is secured by screws that go into some black mounting clips. Has anybody tried to remove these so the number plate will stick flat againt the paintwork? If so how? - just want to know if anybody has done this before I go scratching the paintwork around them!
Thanks,
Old Jul 30th, 2003, 08:56 PM
GazzaK's Avatar
born again MINI owner
England View GazzaK's Chili Red & White 2nd Gen MINI Cooper Profile
if you use the right foam type double sided tape, you can leave the black mounts there, the tape will fit around (not over) it, and will not matter...
'07 Cooper, Chilli Red
||MY MINI||
Old Jul 30th, 2003, 09:14 PM
racermini's Avatar
Local Time: 07:10 PM
United Kingdom View racermini's Cosmos Black & White 1st Gen MINI Cooper Profile
Halfords sell the thick foam sticky pads for about £1.69 IIRC per numberplate.
Black is the new Black.
Old Jul 31st, 2003, 08:47 AM
hurrens's Avatar
Send a message via MSN to hurrens
I fitted my rear plate into a colour coded numberplate holder and then fixed the holder to the rear of the car with double sided foam tape. The holder cleared the original mounting points and fits tight and flush to the bodywork. I tried the double sided foam directly onto the numberplate and then onto the bodywork, but the plate stood proud of the bodywork by a couple of mm. (the thickness of the double sided foam.)
Black Jack
Old Jul 31st, 2003, 11:03 AM
Nic D's Avatar
Wales
How do you remove the rear plate?
Old Jul 31st, 2003, 11:29 AM
hurrens's Avatar
If you are talking about removing the plate from the holder? The numberplate just flexes enough to unclip from the holder. There is rubber/foam around the edge of the holder so the plate does not rattle.
Being able to swop plates in and out is great. I can put on display plates for shows etc. and proper legal plates for driving on the highway.
Black Jack
Old Jul 31st, 2003, 11:40 AM
rhardaker's Avatar
Big Grin...
On my Astra you could just pull the clips out by using a screwdriver and prising them out (they were just like a rawlplug). I'm sure the Mini ones will be similiar it's just a case how similar! They do stick quite proud so I would of thought you would need some really thick pads (or two together but it would be better to get it flusher to the bodywork.
Old Jul 31st, 2003, 11:45 AM
Nic D's Avatar
Wales
Thanks, will try it tonight!
Old Jul 31st, 2003, 08:06 PM
racermini's Avatar
I've just put my new number plates on using the thick sticky pads from Halfords. The thin ones aren't any good for the front as there is a slight curve,
Old Aug 1st, 2003, 08:38 PM
Restyle's Avatar
Damned
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
Forget Sticky Pads, they`re for Gheko`s.
Get some Nice CHROME added by way of Chrome Plate surrounds for around £20 a pair.
They attatch via Hidden screws onto the original holes, & are covered by your Plate.
I left the plastic studs in my plates to cover the original holes, (I was too stingy to go & buy a new set of plates ), & I sort of need the Middle stud for Effect.
Old Aug 1st, 2003, 09:11 PM
racermini's Avatar
Restyle your plate has the measles.
Old Aug 1st, 2003, 09:16 PM
Restyle's Avatar
Damned
Measles HA !
Its Got The Bleedin` MONKEYPOX!
Name:	ccscottish mini trip 2 080.jpg
Old Aug 1st, 2003, 09:20 PM
racermini's Avatar
oooch, a course of antibiotics should do the trick. I bet you needed a wire brush to get those buggers off.
Old Aug 1st, 2003, 09:44 PM
Restyle's Avatar
Damned
They`re the result of my "John O` Groats" MINI Adventure a few weeks back...What a Miserable & Bleak place -it was the only time out of the whole week when it rained.
The Roads up there However were absolutely Brilliant.
The Flies queued up to Die with a Dignity that would make a Klingon Proud.
What a Way to Go .... Start the day off sniffing sheep *****e & Finish off with an MCS Sandwich
Nirvana !
Name:	ccscottish mini trip 2 039.jpg
  #15 (permalink)
Old Aug 1st, 2003, 09:48 PM
racermini's Avatar
Top Class
Front Plate Mounting Location Jacob General Discussion 0 Jul 11th, 2006 02:51 AM
Front number plate mounting and position. What's the law? Root Ginger General Discussion 11 Feb 20th, 2006 06:03 PM
Rear number plate mount TimCS First Generation MINI Cooper S 0 Nov 25th, 2005 03:11 AM
Uk: Replacement rear number plate holder? bimini First Generation MINI Exterior 8 Sep 12th, 2005 07:18 AM
Number Plate Mounting Chilli_Red Australia 9 Jul 12th, 2005 07:52 AM
