| Warning! Armed with Volvo Join Date: Jan 2003 Location: SW London Local Time: 01:38 AM
Offline | Bought my MCS in the Summer and I'm really pleased with it - 100% reliable - no probs - 6000 miles etc etc. However as the morning temperature turns a bit parky I do what I always do on the early morning drive to work; After engine gets warm, turn heat to max, turn blower to max and direct hot air downwards on to my frozen feet ( I have a problem with cold feet ). After two or three miles my feet thaw out and I turn off - end of problem. BUT on MINI the 'down' arrow directs hot air onto feet but half of it also goes up though the two round vents each side of the dash and my head and shoulders feel like they're in a sauna. This is the only car I have ever had that does this ( over 30 cars ) whats wrong with directing air onto the feet only? Is this a problem for anyone else? and apart from blocking the vents with kleenex is their any way to fix this? all suggestions welcome!!!!! |
| Just Motor | I am not sure exactly how the air/vent system works in the MINI (I don't get mine for a few more months), but most cars have a vacum controled diaphragm that controls a flapper that diverts the air (either on the floor, on the dash, both, etc.) I would think that the diaphragm could be broken, stuck, or might have a vacum leak. It is possible that the flapper could also be electronically controlled (instead of vacum controlled). In this case, it might be binding up on something or not recieving propper voltage. I would call the dealership and have them look it over. -John |
Offline | Thanks for that - can anyone with the manual aircon confirm that the same happens to them ie select down arrow on the dial but get hot air going down and upp through the two side vents???? If nobody has his problem I'll have to get mine sorted!! |
| MINI2 Regular Join Date: Dec 2002 Location: London Local Time: 12:38 AM
Offline | Yeah I think that is all part of the design. The vents that air still blows from point on the windows - I assume to make sure they don't fog up. But in my vast experience of cars (I used to drive a Rover Metro, and before that a Tonka truck when I was three!), I am sure my Metro was exactly the same, i.e. you could close off the vents and whatever but there was always a bit of air coming out of the vents that pointed on to the side windows and windscreen. Hope that helps (but I don't think it does!). I think tissues to block up the vents are your only solution! gm ![]() Very special 'chillied' red and white Cooper, 17" alloys, and a very proud owner ![]() Born on 3 January 2003. |
| | #6 (permalink) |
| ITS RAINNIN' SIDEWAYS | i have manual air con & i can't say i've noticed this. i think gooner is right - some air is always directed out through the window vents, but not like how you've described. might be worth getting the dealer to have a quick butchers - could be a hose connected up to the wrong inlet somewhere. do the rest of the settings for air circulation work ok? |
| | #7 (permalink) |
Offline | I think everybody is right here - but on my other cars only about 10% of hot air is sent to the screen - whereas MINI sends 50% through the side vents - which means my head and shoulders get roasted long before my feet thaw out!!! |
| | #8 (permalink) |
| MINI2 Master Join Date: Dec 2002 Location: Dorset, U.K. Local Time: 01:38 AM
Offline | You're definitely correct, BRGreenie. Can't recall coming across such a complicated system. It too is directed at feet, but after the Cotswold run, next day had swollen eyes where the cold blower, which was used intermittently, had been used for the round trip. "I get by with a little help from my friends" |
| Ordering a NEW 'D'ooper, cold feet - talk me into it! | kmpowell | MINI Cooper Diesel | 23 | Sep 23rd, 2007 09:39 PM |
| getting cold feet! | rentagas | MINI Cooper Diesel | 2 | May 30th, 2007 11:41 AM |
| Mini Sponsors New Series of Cold Feet! | Wul | MINI in the Media | 9 | Feb 27th, 2003 10:05 PM |
| Help! Seriously cold feet now... | albi | MINI Cooper S | 12 | Sep 10th, 2002 10:00 AM |
| Getting a MINI and...cold feet...Please, help | GlobeTrotter | Faults & Fixes | 10 | Jan 31st, 2002 05:08 AM |
