Mini Pirate
Old Oct 18th, 2003, 01:23 AM   #1
red03miniS
Local Time: 07:11 PM
Oil Question, Your help requested
Hello there
I have a 2003 MCS, nov 2002 build, that I took delivery on January 29, 2003.
The car is my weekend driver and currently has 2416 miles on it.
The oil in the car has never been changed. Today I started the car, let it warm up for about 10 minutes, washed it, shut it down. I checked the oil level and it has me quite concerned.
The oil level seems to be touching the bottom part of the stick only, thats the only part that seems to be wet. I will try to draw a pic to illustrate my point.
O <-----the little handle for the oil stick (yellow)
I
I
I
I
I
I
xx <----the thick part (on the bottom of the stick) where the oil level should be (I ASSUME)
I
I <---this is the little mesh yellow area
I
I <-----this is where its wet with oil, after car reached operation temperature
xx <-----end of stick
My question is
1) is the car low in oil?
2)should I change the oil, or just add some castrol synthetic?
3)if i should just add, how much do you think I would need?
Your help is sincerely appreciated!
-Ryan
2003 CR MCS and 2007 CR MCS (on order)
United States View red03miniS's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 18th, 2003, 01:48 AM   #2 (permalink)
obehave
Mini Mod
obehave's Avatar
Local Time: 03:11 PM
Quote: Originally Posted by red03miniS
Hello there
I
I
I
I
I
I
I
I
My question is
-Ryan
First, you should have checked it before you started the car or waited at least 10 minutes before checking.
Second, were you on a level spot
Last, if it's at the bottom of the cross hatched area it should be about 3/4 of a quart low.
Mine lost about that much. After 5K miles it really hasn't lost much.
When was the last time you checked it and how quickly did it go away?
Old Oct 18th, 2003, 01:56 AM   #3 (permalink)
red03miniS
ok so i can check the oil in the morning again, when it is cold.
secondly, yes level spot, in my garage
so it is low. so i will go buy some oil tomorrow and fill it up.
is that bad, i mean do you think there is something wrong wtih my engine.
i checked it at 1000 miles, and it was fine then. i havent checked since, because i am too used to my other honda and lexus cars wehre the oil level never changes.
Old Oct 18th, 2003, 01:59 AM   #4 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Local Time: 02:11 PM
During break-in, the car will use a little. Don't worry. Mine took 3/4 of a litre during break-in and then was fine until first oil change. Now before second oil change it is again down another 3/4. The change frequencies are so long that this is no biggie. Unless it drops to the MIN level, you don't need to add yet. Too much is worse than too little.
Harry
Canada View HarryHBMCC's Hyper Blue & Dark Blue 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Oct 18th, 2003, 02:01 AM   #5 (permalink)
red03miniS
so you think i shouldnt add? if i go by schedule it seems like 7500 miles more. its at the bottom.
but i will check again the morning, and see where it is.
exactly at what level should it be? top of the cross hatched part?
Old Oct 18th, 2003, 02:09 AM   #6 (permalink)
obehave
Mini Mod
obehave's Avatar
I don't think you have a problem. Harry and I had about the same usage. Just top it off and check it once a week. You probably won't use much or any more until your first change.
And yes first thing in the morning i sfine.
Old Oct 18th, 2003, 02:14 AM   #7 (permalink)
red03miniS
thank you guys. so i will put in about 3/4 of a quart after i check it tomorrow. thanks for the quick reply.
second question, when did you guys do your first oil change?
Old Oct 18th, 2003, 02:15 AM   #8 (permalink)
NEMINI
NEMINI.org
I used a quart within the first 2-3000 miles and then none after. It is normal to use some during break-in like others stated above, my motoring advisor was even kind enough to tell me to keep an eye out for this when I first picked up my MINI Perfectly normal mate
United States View NEMINI's Silk Green & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 18th, 2003, 02:19 AM   #9 (permalink)
red03miniS
thank you guys again so much!
i love that even on a friday night, i can get answers on this board
so i will just add a quart..and do my first change around the 5K mark, sound ok?
Old Oct 18th, 2003, 02:22 AM   #10 (permalink)
obehave
Mini Mod
obehave's Avatar
"when did you guys do your first oil change?"
Big can of worms there.
I did my first at 1500.
Harry went to 10K if I remember right.
There's a BUNCH of threads on this
Old Oct 18th, 2003, 02:22 AM   #11 (permalink)
NEMINI
NEMINI.org
I'll disagree on the need to change at 5k but thats best saved for another thread . I'd start by adding approx. 1/2 a quart, waiting a good 30 minutes for it to drain down and check again before adding the whole quart.
Old Oct 18th, 2003, 04:19 AM   #12 (permalink)
red03miniS
thanks guys for the help. yeah i read tons of those threads..and dont want to open up another container of worms
just was curious to all of you
gmini--after adding a 1/2 quart, should i start the engine, or just wait 30 min?
Old Oct 18th, 2003, 04:21 AM   #13 (permalink)
NEMINI
NEMINI.org
either way would be fine so long as you give it time to run down into the pan
Old Oct 18th, 2003, 04:30 AM   #14 (permalink)
red03miniS
ok i will check in the morning
go buy some castrol oil (i like mobil 1 better, but dont want to mix oils)
put half in...
let sit for about 30 min
check again..and see
should the oil level (when full, be at the top of the harsh marks?)
Old Oct 18th, 2003, 04:44 AM   #15 (permalink)
NEMINI
NEMINI.org
there abouts, yeah, but don't worry it it isn't all the way up as long as it's between the min and max it's fine
Old Oct 18th, 2003, 05:01 AM   #16 (permalink)
red03miniS
thanks man.
i read the oil change thread..all 11 pages..and had a few questions, since you were quite active on that thread
1)i drive about 3K a year, and you said mini recommends one change a year (is that free by mini?)
2)should i have to wait 3 years to finaly get my oil change from mini?
Old Oct 18th, 2003, 05:12 AM   #17 (permalink)
NEMINI
NEMINI.org
1. I am not positive on the one year thing but I seem to remember something about it in the owners manual (i reserve the right to be wrong lol)
2. I would say waiting 3 years for an oil change would be crazy, if you can't find anything in the owner's manual I'd definately try a call to 1-866-ASK-MINI and see what they say about it.
Old Oct 18th, 2003, 10:21 AM   #18 (permalink)
Alan Tois
Send a message via Yahoo to Alan Tois
I have a May 2002 build Cooper, currently at 34,500 miles. I have only done the oil changes at the recommended iintervals- first was 16,000, second was 29,000.
I checked the oil a couple times between the first and second changes, and was a quart low both times. There were only 4,000 miles between the 2 quarts I added. I made mention of it when I went for the next oil change, and was told "it's normal with extended change intervals".
I have 2 other cars that I use Castrol Syntech in, with 10,000 mile cahnges, and have never lost any oil in either.
I checked the level after the last change, and they overfilled it.
Currently, I am almost a quart low again.
Has anyone heard of oil usage issues beyond break-in?
/al
Old Oct 18th, 2003, 03:48 PM   #19 (permalink)
Dark Silver S
Ultimate Stealth Machine
Dark Silver S's Avatar
Local Time: 01:11 PM
Great advice, CurtP. I would add one thing.
I always start my car, and then fasten the seat belt. This gives the oil a chance to come to pressure before I zoom off. Not too long, just a short time.
Dark Silver S
http://revorg.org/images/mmg.gif
Now in Wilkes County NC
Old Oct 18th, 2003, 05:09 PM   #20 (permalink)
red03miniS
thanks everybody for thier advice. my car sits 6 days between driving.
if the computer takes in time as a key factor..well mine is saying i should change it at 11K, which would be almost 3.5 years!
Oil Question MiniSMan General Discussion 2 Dec 15th, 2004 12:13 AM
A question about oil Pauly General Discussion 15 Dec 1st, 2004 07:38 PM
Change oil question? mcse2k_i Hong Kong 7 Nov 27th, 2004 05:31 AM
oil change question hallo Maintenance & MINI Care 2 Dec 2nd, 2003 09:35 PM
Another Oil Change Question Rudavius General Discussion 2 Jul 5th, 2002 04:49 PM
