Is the MCS supercharger always engaged - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 23rd, 2003, 04:12 PM
JohnWB's Avatar
Local Time: 08:14 PM
United Kingdom Male View JohnWB's Laser Blue & Black 2nd Gen MINI Cooper S Profile
United-Kingdom Is the MCS supercharger always engaged
This may seem like a daft question but on some cars the supercharger is only engaged when you need the extra power as this saves having to drive the superchager all the time and waste power. I have always assumed that it was engaged full time on the MCS but I htought I would ask. Regards John
Laser Blue / Black MCS - Arived March 07
Old Nov 23rd, 2003, 05:03 PM
United Kingdom Male View Spacer's Chili Red & Black 2nd Gen MINI Cooper Diesel Clubman Profile
But, I do remember something about there being a bypass value, that below a certain RPM (I believe 3000 was mentioned), the bypass value is open, allowing the air to miss the supercharger blades. The reasoning behind this was that it was creating more drag than compression. Sorry if the facts aren't quite right, and anyone who can either link to the thread, or correct me, then feel free.
Old Nov 23rd, 2003, 06:35 PM
GTmini's Avatar
Local Time: 12:14 PM
United States View GTmini's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
I've also heard the same thing that Spacer has
Old Nov 23rd, 2003, 09:53 PM
Andy@Ross-Tech.com's Avatar
Send a message via AIM to Andy@Ross-Tech.com
Local Time: 03:14 PM
Spacer is right, there is a bypass valve. Basically, when not under load, air pressure is balanced between the inlet and outlet of the supercharger. So, the supercharger is spinning, but it is spinning in air, not using much power.
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Nov 24th, 2003, 01:42 PM
obehave's Avatar
Mini Mod
I think the original question may be worded a bit oddly. The SC is always engaged. It's just not always using the output.
All SCs are always engaged.
Just to clarify it's not the Mad Max flip a switch Supercharger
Old Nov 24th, 2003, 02:30 PM
JohnWB's Avatar
Wink
Thanks for all the replys,
its just the Mad Max Drivers who have the cars
New SuperCharger and Exhaust in 05 MCS! cfranklin First Generation MINI Cooper S 7 Apr 30th, 2004 07:57 PM
Ticking when clutch not engaged Quentin First Generation MINI Cooper S 17 Apr 1st, 2004 10:01 PM
MCS Supercharger vs Works Supercharger LMB First Generation Works 60 Jul 15th, 2003 07:41 PM
MCS Supercharger ericg_0059 First Generation MINI Cooper S 1 Oct 9th, 2002 02:40 AM
