Bulb Replacement (brake lights in white tail light cluster) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 24th, 2003, 07:03 AM
snarl's Avatar
NON STOP
Local Time: 08:24 PM
United States View snarl's Solid Black & White 1st Gen MINI Cooper S Profile
Okay, I was told my left brake light was "dimmer" than the right so I checked it out. I found the bulb bracket was not fitted correctly and was hanging loose back there. The result was a broken globe on the bottom (brake) lamp. The bulb is functioning but loses much of the needed red color in the white replacement rear clusters. I pulled the bulb pannel to have a closer look and found the bulbs are soldered to the board!!! What the heck is that all about? My dealer is closed for the holiday (by the way Happy Christmas and thanks for reading). I'm sure it was a faulty install, but I'm wondering on what the replacement cost will be.
Anyone encountered this with the white tail lights?
Now this is fun:
Old Dec 24th, 2003, 07:08 AM
mikeythemini's Avatar
My dealer quoted £30 for the bulb rack.
Or if you can source one bulb ( I only keep the silver orange ones at the moment), unsolder and just put a new bulb in, thats what I will be doing
Mike
Old Dec 24th, 2003, 04:35 PM
snarl's Avatar
NON STOP
Can I use the original bulb brackets?
I just got the chance to look at the original lights (the dealer returned to me after my install). At a glance the brackets for the bulbs look the same except you can change the bulbs thank you very much.
Any problem with using the original brackets? It would be worth the pice of a new set of bulbs all around to not have to undergo the construction project of soldering the bulbs in and out.
Now this is fun:
Old Dec 26th, 2003, 03:05 PM
snarl's Avatar
NON STOP
This may be bad form, but I thought maybe not many folks got to see this during the holiday. I'll be looking for bulb replacements tomorrow and plan to use the factory original boards...unless someone can tell me that would be a bad idea.
Looking for some advice and/or encouragement here.
Now this is fun:
BMW White Lights, how to change brake light bulb? The Works First Generation MINI Exterior 9 Oct 17th, 2011 10:54 PM
R56 tail/brake bulb picard Second Generation MINI Exterior 9 May 25th, 2010 08:16 AM
Tail Light Bulb Holder MickCooperS First Generation MINI Exterior 2 Apr 16th, 2006 05:53 PM
Remove rear (tail) light cluster? nigelmercier First Generation Faults & Fixes 4 Mar 13th, 2006 06:27 PM
Tail light cluster loop jcsinnh First Generation MINI Exterior 10 Jul 19th, 2005 08:27 PM
