Visit Derek Woodman MINI
Old Jan 8th, 2004, 07:40 PM   #1
Hoffie
Mainly an onlooker
Hoffie's Avatar
Local Time: 06:20 PM
Sunroof blind is not "dense" enough
Here in sunny South Africa, my bald spot still gets sun burnt through the closed sunroof and closed blind! Any ideas on making the blind or sunroof more "dense" (for want of a better word) to prevent the sun from shining through?
South Africa View Hoffie's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 8th, 2004, 07:44 PM   #2 (permalink)
NEMINI
NEMINI.org
Local Time: 11:20 AM
United States View NEMINI's Silk Green & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 8th, 2004, 07:47 PM   #3 (permalink)
Spy Car
I miss Ruthie
Spy Car's Avatar
Local Time: 09:20 AM
Online
You could put on one of those sunroof-only perforated roof flag decal jobs....they are said to cut down the light and look pretty cool.
Or there is always Rogaine
View Spy Car's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 8th, 2004, 07:55 PM   #4 (permalink)
Hoffie
Mainly an onlooker
Hoffie's Avatar
Quote: Originally Posted by GMINI03
tint it.
Yep, that's it! The simple solutions are always the easiest! Silly not thinking of that myself...
Thanx
Old Jan 8th, 2004, 08:40 PM   #5 (permalink)
Paul
Trained Monkey
Paul's Avatar
Local Time: 05:20 PM
Where abouts in South Africa are you?
Old Jan 8th, 2004, 09:39 PM   #6 (permalink)
AprilWhine
Loves the Fuzzy One
AprilWhine's Avatar
Send a message via AIM to AprilWhine Send a message via MSN to AprilWhine Send a message via Skype™ to AprilWhine
I put paper between the retractable screen and the sunroof, when the sun is too bright. Easy, and also easily removed.
Global Moderator
United States Visit my Blog at the Motorcade Female   Reply With Quote
Old Jan 8th, 2004, 09:57 PM   #7 (permalink)
Minimum
MINI2 Something or Other
Minimum's Avatar
I had a bunch of cheap window tinting material leftover from an old project and applied some to my sunroof last summer and had a pretty good result.
It was a 20% grey vinyl static-cling type that you simply cut to size, moisten the surface and use a squeegee to attach it. There's no adhesive so it's easy to peel off if you don't like it, or if you mess it up.
A good way to trace the areas that you need to cut is to lay the material on top of the sunroof and shine a lite up from below.
Some of the drawbacks were:
  1. It's a two person job to apply since gravity works against you while you try to get enough material to contact the window surface to keep it from falling off.
  2. The stuff I used was so cheap, the sun's heat ended up shrinking the material, causing it to eventually fall off. I found I had to pre-shrink the stuff in boiling water before cutting a new set.
Old Jan 8th, 2004, 11:57 PM   #8 (permalink)
Hoffie
Mainly an onlooker
Hoffie's Avatar
Germiston / Boksburg (East Rand).
Old Jan 9th, 2004, 01:36 AM   #9 (permalink)
Bilbo Baggins
Bilbo Baggins's Avatar
Local Time: 12:20 PM
Hoffie,
Sell what you have and buy one without the sunroof. You will save 60 pounds(27Kg) placed at the top of your car. You would lower the center of gravity and reduce the overall weight of the car, increasing the performance capabilities all in one shot. Plus, no more sun burned scalp.
If you choose a white roof it will reflect sunlight and keep the interior cooler as well.
'06 MCS SB/S R84s(Dunlop 5000, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 9th, 2004, 02:19 AM   #10 (permalink)
Cape Cod MINI
Exposing the Beast
Cape Cod MINI's Avatar
I did the same with a road map to block the sun. Opened the sunroof on Rt. 95 at speed and Maine, New Hampshire and Vermont got sucked out real quick They then got stuck on the radio antenna and made quite a ruckus as the map shredded and flapped in the wind. Gave us , and those folks from New Brunswick gawking at us, a good laugh.
Missing my buddies Dan and Ed but glad I have two angel buddies, And on a quest to Right Secco's Wrongs
Old Jan 9th, 2004, 02:23 AM   #11 (permalink)
mrhollio
road trip time
mrhollio's Avatar
Arn't there any aftermarket replacement screens that are solid instead of perforated?
Trust not the heart of a man for whom old clothes, and the Mini, are not venerable!
United States View mrhollio's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 9th, 2004, 02:53 AM   #12 (permalink)
BruceK
Moderator & Sponsor
BruceK's Avatar
Local Time: 10:20 AM
Most professional window tinting shops refuse to tint glass sunroofs because they claim it can cause the sunroof glass to shatter on hot days. I don't know if it is really a risk, or just an "old wive's tale" in the industry.
Old Jan 9th, 2004, 05:34 AM   #13 (permalink)
agent_spacemonkey
wait, i'm curious...aren't the moonroof already tinted?
agent_spacemonkey
Old Jan 9th, 2004, 05:57 AM   #14 (permalink)
tavis1
a.k.a Handsome Rob
tavis1's Avatar
I don't think so but, that is an excellent idea!
Tavis1
United States Male View tavis1's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 9th, 2004, 06:22 AM   #15 (permalink)
jimskater
Heading down the aisle
jimskater's Avatar
Send a message via MSN to jimskater Send a message via Yahoo to jimskater Send a message via Skype™ to jimskater
A baseball cap? Or any kind of give-away cap. Price range: free to $25 US...
www.scmm.org GP 0101
United States Male View jimskater's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 9th, 2004, 01:37 PM   #16 (permalink)
Minimum
Minimum's Avatar
My shade was replaced since some fool stretched it out when the car was on the showroom floor. Replacing them requires removing the headliner - not an easy task.
Old Jan 9th, 2004, 03:20 PM   #17 (permalink)
Paul
Trained Monkey
Paul's Avatar
Ah cool. I'm still waiting from somome from Cape Town to join up, have relatives there.
Sunroof blind DeanS MINI Cooper S 13 Jun 13th, 2007 08:40 AM
"Spooky" Sunroof Opening PeskyD MINI Convertible 7 Aug 16th, 2004 03:47 PM
Sunroof "modification" Question MCjunkie General Discussion 8 Sep 22nd, 2003 10:41 PM
Sunroof "pads" lotoole3 Faults & Fixes 1 Sep 16th, 2003 03:34 PM
Mirrors with "blind angle" part mhoutman Interior & Ice 15 May 13th, 2003 12:00 AM
