| MINI2 Newbie Join Date: Jul 2003 Location: Derby Local Time: 01:53 AM
Offline | Tyre Pressure light The little yellow light on the dash keeps coming on telling me I have tyre pressure problems, but when I check the pressure they seems alright. I turn the engine off and it resets - then nothing. It doesn't happen every journey, just now and again...but at least once a week. Is this a common 'foible' or do I need to get it checked out with a dealer. I haven't had any new tyres yet - but I take it the runflats are expensive? |
Offline | Thanks mate, but I've done that! I dunna want to take it to the dealer if I can help it...I'm sure they'll scratch their chins, take a sharp intake of breath and tell me I need to spend loads of pounds! I've check the tyres for signs of deflation and stuff but they seem OK. bloody thing. |
| | #6 (permalink) |
| MINI2 Senior Join Date: Feb 2004 Location: Liverpool Local Time: 02:53 AM
Offline | dont know if this is of any help to you but if you have the runflats I picked my MC up on monday and the dealer told me that sometimes in the below freezing temp the run flat sensor can sometimes show up when it shouldnt do and if it happens just to reset it........I dont know if its been cold were you are but thought it best to tell you what they said to me if it can help???? |
| | #7 (permalink) |
| MINI2 Master Join Date: May 2002 Location: Edinburgh Local Time: 02:53 AM
Offline | Is it flashing or does it come on and stay on? From memory flashing is the indication that you have a low pressure tyre whereas if it stays on it signifies a fault with the system. Red/Black R56 Cooper |
| | #11 (permalink) |
| Slippery When Wet | I've had the same problem with mine. 100% sure its not an actual tire pressure issue but just a computer problem. It happens at random times... we can't figure out an common occurance that may have caused it. I haven't seen it again since my first service visit though... here's hoping -Stef back in action |
| | #12 (permalink) |
| MINI2 Regular Join Date: Aug 2003 Local Time: 01:53 AM
Offline | So if u put any air in / take any out you have to reset the indicator each time is that correct? And do i read the manual correctly (where's the plain english!!?) - turn ignition to position 2, hold button below handbrake until yellow light on speedo is lit, then release, start and driver away... correct?! thanks in advance! |
| | #16 (permalink) |
| MINI2 Newbie Join Date: Mar 2004 Local Time: 02:53 AM
Offline | answer??? hi all, yea i had this problem back in about september. the tyre pressure light came on every so often at first but then about 15 secs after every time i started the car! drove me nuts so i ended up taking it in to the dealer to sort. at first they didnt know what it was so they reset the fault diagonstic thingy so when it happened again hopefully the on board computer would tell them what it was, but no... anyway they narrowed it down to the DSC (do u have DSC or ASC?) and fitted a whole new DSC unit (all under warranty might i add!) .this seemed to clear the problem for about another 3 days then the ![]() ![]() ![]() ![]() ![]() ![]() came on again! Anyway to round it up (cos im probably waffling!) they said the DSC unit they fitted must have been faulty so they replaced it again and i haven't had the problem since!! (and not one penny spent... expect taking it in and out of the dealership 3 or 4 times!) hope that solves your problem! Dealership that fixed it by the way was coopers service department in sevenoaks, kent. they were actually very good about the whole thing and were very helpful, mayb give them a call as they have seen the problem before??? |
| | #17 (permalink) |
| MINI2 Newbie Join Date: Sep 2003 Location: Cardiff Local Time: 02:53 AM
Offline | My tyre pressure sensor is really annoying me. I hit a pothole the other day and popped one of my tyres (bl00dy Welsh roads ). The sensor didn't come on (although it was obvious that I had a flat).I changed the wheel and two days later, the sensor came on, pinging away and generally bugging me. I checked the tyre pressures and they were fine. Mini told me that I had to reset the sensor when I changed tyre. This week, I has another flat due to some grit in the tyre vale letting air out. Guess what? No light from the sensor! I re-inflated the tyre and had the wheel checked my a garage. Later that day, the sensor came on again. ARRRGH. What a complete waste of time. These sensors are useless. |
| Tyre Pressure Light | coded2112 | John Cooper Works & GP | 3 | Mar 6th, 2007 08:02 AM |
| Tractiong control & tyre pressure light on | Tombles | Faults & Fixes | 5 | Feb 15th, 2007 11:05 AM |
| Tyre pressure light | Mini Cruiser | Wheels, Tyres & Brakes | 4 | Apr 5th, 2005 01:03 PM |
| Tyre Pressure warning light. | geonot | Faults & Fixes | 16 | Dec 15th, 2003 08:19 PM |
| tyre pressure light - superb safety feature | mikeythemini | General Discussion | 3 | Dec 6th, 2002 09:03 AM |
