| Search for snow, both in the galleries and in the forum. (Also check out the stickied snow tire gallery) The only way you'll prove to them if is someone from the same area as you has driven a MINI and posted to show how well it did. And btw: The FAQ on DSC should explain how its almost impossible to spin the tires because of the traction control aspect - and they are right about ground clearance, above 4" of snow, you might get stuck, but do you really expect to drive in more then 4" of unplowed snow? Its pretty rare most anywhere there's a MINI dealer. Otherwise with snow tires, you're fine. (Without you're on your own... some people have done ok, most people haven't) Magic 8-ball was correct. All be in awe of Magic 8 ball. |
| Fold the rear seats, travel to the store, and stockpile 2-weeks worth of back-up supplies at the start of winter? Like stryder said, 4-inches of unplowed snow may be fine. The main problem is the plowed snow banks at the entrances of driveways and side streets. If they are much higher than than the minimum ground clearance of your car, you have a good chance of being stuck. Roberto |
| How are minis in the snow? | MiniCooperMax | General Discussion | 15 | Jan 31st, 2005 02:50 AM |
| MINIs in the snow | mgemie | First Generation MINI One | 9 | Jan 29th, 2004 03:05 PM |
| MINIs in the Snow? | MarkW19 | General Discussion | 10 | Dec 23rd, 2003 07:46 PM |
| MINIs in the Snow! | nonsequitur | General Discussion | 6 | Oct 23rd, 2003 05:41 PM |
| How do Minis go in the snow? | andrewebel | General Discussion | 13 | Dec 26th, 2001 01:50 PM |
