| Clutch in during cornering? A search on this topic was unsuccessful.... I was under the impression that it was better to push the clutch in while cornering, then match the revs while exiting the corner (learning how to read the apex of a curve/corner is critical), and releasing the clutch. However, in the Edmunds article about Heel & Toe here What do folks here do/recommend? Do you drop speed/revs/gear before entering a turn and not depress the clutch? Or do you clutch in the middle of the turn? Granted, we're not racing, but we are doing spirited driving, eh? |
| Being that it is FWD, accelerating in the turn will transfer the weight to the rear tires causeing you to get more traction by destributing the weight more evenly. |
| The WORST thing you can do on any front-wheel drive car is to fail to accelerate during cornering. If you want to be going backward in a front-wheel drive car, the easiest way to do it is to enter a sharp corner without your foot on the throttle! , this is NOT a good thing... Tom 02 EB/B MCS |
| Never heard anyone recommend clutch in while cornering. Adjust speed BEFORE the corner and accelerate through the corner. Slow In - Fast out Fast In - Feet Out (into the ambulance) |
| No No No No Noooooo. I can't even imagine cornering with the cluth in. zwiiiing, right off the side of the mountain. Depending on the speed I want to enter, I might drop down a gear, but I am always in gear none the less. I don't drive too fast ... you just look too slow! We're not lost ... this is the scenic route ![]() Mr. Q's blog |
| Worrying suspension noise when cornering | lusomini | First Generation Faults & Fixes | 6 | Feb 23rd, 2007 11:53 PM |
| Strange Noise when cornering | The Saint | Wheels, Tyres & Brakes | 2 | May 5th, 2006 08:16 PM |
| Cornering Top 3-Who are other 2 makes? | jimmy_racoon | General Discussion | 40 | Jan 20th, 2006 01:01 AM |
| Headlights intensity decreasing while cornering | Qwerty | First Generation Faults & Fixes | 6 | Dec 9th, 2002 11:04 AM |
| ASC = Automatic Slow Cornering | jmardy | General Discussion | 3 | Sep 18th, 2002 02:09 PM |
