Old Mar 30th, 2002, 11:14 PM   #1
mini mucker
mini mucker's Avatar
Local Time: 05:04 AM
which of these will invalidate the warranty??
powerflow custom exhaust backbox
lowering 30mm
spoiler from auofashion
alloys
ice
and how to prefent this,what other makes are suitable ?
DoNt DrInK aNd DrIvE,sMoKe AnD fLy HoMe!!!!!
Old Mar 31st, 2002, 03:09 AM   #2 (permalink)
BrantV
BrantV's Avatar
Local Time: 09:04 PM
Nothing, and possibly everything.
I don't think any of the mentioned items will void the entire warrantee, but any of the items could void certain failures. If they can show that it was likely caused by the modification.
Lowering will change the angle of the drive shafts. While it is designed to be compressed, under load much further than a few cm, could changing the default angle alter the life span of the u-joints?
Spoiler? Other than a bad mount causing leakage, mildew damage, and or rust, I really can't see any problems.
Given the number of dealers that want to force after market Alloys on the new MINI, you'd think they'd be a safe bet. But if you don't get the correct offset, you could put extra stress on the front suspension. Going with too large of a tire/rim could rub or collide with suspension and body parts diminishing their life span.
A bad ice install could damage the wiring. If they have to pull panels, and you develop a squeak, it's no longer MINI's fault. Whose fault is it if someone's base rattles things loose?
United States View BrantV's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 31st, 2002, 04:41 AM   #3 (permalink)
Basil
Local Time: 03:04 PM
I would suggest you talk to your dealer. Let's face it, If you don't and something goes wrong.......
cheers
England   Reply With Quote
Old Mar 31st, 2002, 04:59 AM   #4 (permalink)
smiffy
smiffy's Avatar
Send a message via MSN to smiffy
Alloys & ICE shouldnt effect the warranty in any way, only the items you replace woiuld void the warranty for that part, ie a standard exhaust for an aftermarket jobbie
S for Smiffy
"Kids in the front seat cause accidents, accidents in the backseat cause kids!"
Wales View smiffy's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Mar 31st, 2002, 12:24 PM   #5 (permalink)
OS2Jihad
Local Time: 12:04 AM
Send a message via ICQ to OS2Jihad Send a message via AIM to OS2Jihad
Re: which of these will invalidate the warranty??
lowering 30mm
alloys
ice
There was a LONG debate about this over on the Club3G (Mitsu 3rd generation Eclipse) board a while back. The general consensus was this: NONE of the modifications above will void your 'warranty' so to speak, as your warranty is not an all-encompassing item. What it WILL void are the covered repair / replacement costs of any part you have replaced with an aftermarket part. For example, I have replaced my factory air intake and exhaust on my 3G Eclipse. I have not voided my 'warranty', but I have voided the warranty on my factory air intake an exhaust. Should I have a problem related to either one of these, I'm out of luck. Should I have a problem with my suspension (which I have not yet changed), I would be OK.
As other folks have probably also mentioned, the dealer may attempt to use your installed after-market parts as an excuse not to honor other (unrelated) warranty claims -- your milage may vary.
Hope this helps --
Jeff
Old Mar 31st, 2002, 02:40 PM   #6 (permalink)
mini mucker
thanks very much everyone,my mind is at rest!!
gav
Old Mar 31st, 2002, 05:47 PM   #7 (permalink)
12000rpm
so wot exactly does the TLC cover??? some ppl are saying u can change stuff but some say it will void the warranty?
Extended warranty - any experience with Warranty Direct? GNDMini General Discussion 3 Oct 21st, 2005 03:25 PM
Will these invalidate my warranty? Pinball General Discussion 5 Sep 10th, 2004 09:54 PM
It will invalidate my warranty! Zob Interior & Ice 12 Apr 18th, 2004 05:40 PM
Invalidate Warranty by installing new stereo Kinster Interior & Ice 2 Mar 2nd, 2004 09:05 AM
NON BMW Springs invalidate Warranty !!! Ultimate Works Suspension 31 Jan 10th, 2004 01:10 PM
