Old Apr 19th, 2004, 07:39 PM   #1
Revolver
Mentalist
Revolver's Avatar
Local Time: 08:00 PM
Does turning off DSC turn off ABS?
I doubt this is the case but the manual implies that ABS is off when DSC is off, I think by including ABS as one feature of DSC (can't recall exactly, manual not with me). Is this the case?
Canada View Revolver's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 19th, 2004, 07:44 PM   #2 (permalink)
Martin L
MINI defector
Martin L's Avatar
Local Time: 01:00 AM
When you turn off the DSC this also turns off the traction control ASC+T and not ABS
MINI, RX8 and MX5 - Done those............. It's now TTime
Unofficial MINI2.com bean counter
England Male View Martin L's Astro Black & Body Color 2nd Gen MINI Cooper Profile   Reply With Quote
Old Apr 19th, 2004, 07:45 PM   #3 (permalink)
Ady
Tinkering In The Garage
Ady's Avatar
Send a message via MSN to Ady Send a message via Skype™ to Ady
The simple answer is no, turning off DSC turns off the stability part of the system, the part that monitors what the car is doing and makes adjustments. Although DSC and ABS systems are linked ABS operates seperately. I might not have put it well here but that is my understanding of the 2 systems.
Ady
United Kingdom Male View Ady's Chili Red & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Apr 19th, 2004, 08:59 PM   #4 (permalink)
Theo
Resident Panpsychist
Theo's Avatar
Send a message via AIM to Theo
Ady
R50 --
You are correct, Sir!
When the DSC systems predicts the car's impending flirtation with danger (via the g forces, speed, steering angle sensor, and other bits), it uses the ABS system's ability to modulate braking at appropriate wheels along with a throttle override to bring things under control. A DSC subsystem, Corner Brake Control, also uses ABS.
ABS cannot be turned off with the DSC toggle.
FWIW,
Theo
"The nice thing about Alzheimer's is you get to hide your own Easter eggs." - John McCain
Egypt View Theo's Liquid Yellow & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 20th, 2004, 06:19 AM   #5 (permalink)
phazer
Local Time: 03:00 AM
South Africa
On BMW's (well on my ex e36 323i) if you press the ASC button in and hold it down for a while it turns off ABS aswell. Might work with the Mini's aswell. I believe it was a feature that BMW included for people driving in snow, as you can break faster in snow with ABS off, cause of the snow that "piles up" infront of the tyres.
South Africa   Reply With Quote
Old Apr 20th, 2004, 08:06 AM   #6 (permalink)
brassd
brassd's Avatar
Interesting I'd not heard of that. I'll try it on my way home!
Dave
United Kingdom View brassd's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 20th, 2004, 10:46 AM   #7 (permalink)
Paul
Trained Monkey
Paul's Avatar
Doesn't work on the MINI.
Our trials and tribulations living in a "bleeding edge" eco house... Oxley Woods Living
Old Apr 20th, 2004, 04:41 PM   #8 (permalink)
Theo
Theo's Avatar
phazer --
I'm pretty sure that in my E46, pressing the DSC button turns off DSC and holding the button for 5 seconds will turn off ASC+T, not ABS. I'm not sure that this is true for the E36, though. I will verify this with the bible (Bentley Manual), but I'm pretty sure there is no way to override ABS on a BMW or MINI. I will correct myself in a subsequent post if I have erred.
And Paul is absolutely correct; in a MINI you cannot turn off ASC+T with the DSC button like you can in a BMW E46.
FWIW,
Theo
Old Apr 20th, 2004, 06:28 PM   #9 (permalink)
KlausR
KlausR's Avatar
Quote: Originally Posted by Theo
phazer --
Theo
Thatīs fairly correct. To be precise just tipping the DSC button leaves you in traction mode, which doesnīt mean ASC+T is active, but that the brake intrusions stay active to prevent single wheel slipping but without throttle override. Holding the button for 3 seconds also deactivates the traction mode. ABS stays active all the time! Afterall there isnīt any single reason to deactivate ABS as it optimizes the braking performance and vehicle control under most conditions. The only conditions that result in shorter stopping distances without ABS are thick layers of snow and gravel which arenīt appropriate occasions for speeding.
Klaus
Donīt bother me with: Vans, SUVs and Grandpatronic
Germany View KlausR's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 20th, 2004, 07:48 PM   #10 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Quote: Originally Posted by KlausR
... ABS stays active all the time! Afterall there isnīt any single reason to deactivate ABS as it optimizes the braking performance and vehicle control under most conditions. The only conditions that result in shorter stopping distances without ABS are thick layers of snow and gravel which arenīt appropriate occasions for speeding.
Klaus
Unless you're rallying of course... Even when not rallying, if you must drive in winter on a daily basis you do have to become used to the performance of ABS. It steers you straight which is good but on glare ice it sometimes feels like the car will never stop, even with winter tires. I still think it is best for most driving situations but the system could use some refinement. Its activation (both ABS and traction control) when going over bumps is most annoying.
Harry
Canada View HarryHBMCC's Hyper Blue & Dark Blue 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Apr 20th, 2004, 09:10 PM   #11 (permalink)
Theo
Theo's Avatar
{snip} To be precise just tipping the DSC button leaves you in traction mode, which doesnīt mean ASC+T is active, but that the brake intrusions stay active to prevent single wheel slipping but without throttle override. Holding the button for 3 seconds also deactivates the traction mode.
{snip} Klaus
Thanks for the clarification, Klaus! This applies only to the E36/E46 and not the MINI.
Theo
Old Apr 20th, 2004, 10:00 PM   #12 (permalink)
Paul
Trained Monkey
Paul's Avatar
Quote: Originally Posted by HarryIndiBlue
....but on glare ice it sometimes feels like the car will never stop, even with winter tires....
Experienced that for the first time in Abi's company car some years back. Scary stuff! I'm braking... oh crap, no I'm not..... aaaaah.....
Old Apr 20th, 2004, 11:04 PM   #13 (permalink)
KlausR
KlausR's Avatar
Harry
I usually avoid driving on ice. But itīs true, if the friction is very low, the pulsation rate of the ABS is too high, so that the effective deceleration drops even more than would be expected from the slippy conditions.
@Theo
That adjustable DSC wasnīt even available during the whole E46 production, but was introduced on the 2001 model I think. The E36s had only ASC+T which could be switched off completely like today on the MINI. Actually there are quite many different versions and strategies concerning the access to DSC functions throughout the car market. After the moose test crisis the Merc A-classīs ESP cannot bei switched off at all and on some other Merc models the ESP button only alternates the cut-in threshold.
Klaus
Old Apr 21st, 2004, 12:36 AM   #14 (permalink)
Theo
Theo's Avatar
{snip}
{snip}
Klaus
I believe the '99 E46s were still ASC+T. The '00s had the adjustable DSC...at least my 2000 328i does!
Cheers,
Theo
Dsc do u turn your dsc off in the rain lunlun MINI Cooper S 32 Nov 24th, 2006 08:49 AM
ABS DSC Fault tangodancer Faults & Fixes 34 Oct 6th, 2006 11:23 AM
ABS and DSC noise/rattle leem Faults & Fixes 4 Jan 26th, 2005 01:22 PM
Big Brakes vs. DSC/ABS? smlawrence Engine & Drivetrain Tuning 3 Jun 1st, 2003 09:58 PM
Turn off A/C before turning off car? plaztik General Discussion 25 Apr 26th, 2003 02:43 PM
