Old Jun 5th, 2004, 09:42 PM   #1
1703
Local Time: 06:07 AM
Driving light on only with high beam...
Hi all,
I just have the driving lights installed today and they can only turned on with the high beam. Is that the correct setup? Can I have it reset to turn on at any time?
Thanks in adance.
1703
Cambodia   Reply With Quote
Old Jun 5th, 2004, 09:58 PM   #2 (permalink)
ALD0
ALD0's Avatar
Local Time: 07:07 AM
Yes that is how it should be-I would not reckomend having it re wired on a Independant switch.
They are great as they are now!!
Spain Male View ALD0's Hyper Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 5th, 2004, 10:36 PM   #3 (permalink)
andyupnorth
andyupnorth's Avatar
That's the correct set-up. It's illegal in the UK to have driving lights on with dipped beams.
"Do try to keep up Nigel!"
Old Jun 7th, 2004, 10:24 AM   #4 (permalink)
wardmj1
The car in front...a Mini
wardmj1's Avatar
??? Is this the case? My driving lights are independatly switched on and work with any beam on.
Am I driving illegally? My car came like this!
Old Jun 7th, 2004, 10:26 AM   #5 (permalink)
MukiMunki
I reckon it's supposed to be main-beam only. Wardmj1 - are yours MINI or aftermarket?
54 Plate All Black Cooper S with Chilli, BoostCD, MFSW, Heated bits.
http://www.evoposters.net/carsb/album43
Old Jun 7th, 2004, 10:27 AM   #6 (permalink)
ALD0
ALD0's Avatar
Only if you drive abot with them on all the time.
Old Jun 7th, 2004, 11:10 PM   #7 (permalink)
xplode
minimalist
xplode's Avatar
Local Time: 02:07 AM
i don't know that this is actually true? if it's illegal to drive with driving lights on with dipped beams, it's likely illegal to have them wired to even work that way?
cooper s '05
x brg/white/chrome, cordoba/anthracite/chrome, flik wasp 17x7
x delivered july 26th 2005
cooper '02 replaced
x brg/white, R83 white, chrome, cordoba
x built june 21st, arrived july 15th on the traviata, delivered july 26th 2002
United States View xplode's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 7th, 2004, 11:58 PM   #8 (permalink)
Tom D
Local Time: 01:07 AM
As I understand this, the driving lights are the halogen bulbs at half voltage. The xenons are not used for driving lights. The driving lights are on at all times while the engine is running, unless the emergency brake is on. Unless it is different in the UK, that is how they work on this side of the pond. Perhaps Paul can verify.
Tom
02 EB/B MCS
United States View Tom D's Electric Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 8th, 2004, 06:25 AM   #9 (permalink)
astra
SCMM.org member
astra's Avatar
Local Time: 10:07 PM
Send a message via AIM to astra
I think you are confusing the Daytime Running Lights for the driving lights..
I know that in the US.. the usual gag is that "driving" or auxillary lights can only be used in conjunction with "high" beams..
and "fog" lights should only be on when the dipped beam is on..
most of my past vehicles have been wired this way from the factory.. of course having the fogs and the low beams on sometimes is really useless in heavy fog.. you really want the fogs to cut under..
the other consideration is number of lights and the legality there.. in Ca, you can only have 4 headlights illuminated at any one time.. so in theory ,, it is ileagle to have the main beam, fog and driving lights on at the same time..
11/03 BRG/Wht MCS EBC Rotors/ EBC Green Pads, Schroth 4 point harness, Nitto NT-450 215/40/17 17" Zenetti Vega, H Sport Total Vehicle Suspension, MINI Fini Sport Link/Bike Rack, SSM, One Ball Exhaust
Old Jun 8th, 2004, 08:09 AM   #10 (permalink)
ALD0
ALD0's Avatar
How confusing is this now!!
Your Spot lamps should only be on if you have you High beam on-You shouldn't drive around with them all the time-otherwise you blind everyone. You can turn them on all the time if you have a independant switch which I wouldn't reckomend!
Your Fog lights can come on even if you just have your sidelights on but should only be used for when it's foggy!!!
Old Jun 8th, 2004, 08:52 AM   #11 (permalink)
MiniAdventurer
*mysterious girl*
MiniAdventurer's Avatar
i have driving lights that only come on on high beam- i think you'd blind everyone if you drove about with them on while on dipped beam!
United Kingdom View MiniAdventurer's Pure Silver & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jun 8th, 2004, 10:54 AM   #12 (permalink)
JpMcC
JP :-)
JpMcC's Avatar
is it possible to have the spot lamps on a different switch, for instance where the ASC switch is suppose to be, I dont have this feature but would like to be able to add an extra switch that could be used for the spot lamps!!!
any help appriciated, jp
The R56 lives another day.. time for the modifications to begin
Old Jun 8th, 2004, 11:47 AM   #13 (permalink)
Wobert
Mr 120d Sport
Wobert's Avatar
Interceptor is quite correct......the spotlights do not have beam deflectors, to guide the light beam towards the nearside of the road. As such, they should be treated as additonal MAIN BEAM lights, and should therefore only be lit when main beam is on.
You can wire them differently, but you should legally only use them as above.
To do otherwise could leave to open to being pulled by the boys in blue.
Robert
United Kingdom Male View Wobert's Dark Silver & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Jun 8th, 2004, 04:15 PM   #14 (permalink)
mad brummie
I Just Can't Get Enough
mad brummie's Avatar
Send a message via MSN to mad brummie
i wouldn't want mine wired any other way than on main beam, they are too damn bright to be used safely for anything else.
United Kingdom View mad brummie's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 8th, 2004, 04:33 PM   #15 (permalink)
MukiMunki
If they were wired separately how would you dip them in a hurry if there was oncoming traffic?
Old Jun 8th, 2004, 04:52 PM   #16 (permalink)
Johnny225
Mr Buttons!
Johnny225's Avatar
I'm actually glad they can only be turned on with the high beams, as they are extremely bright. The only time I use them is on an open country road at night with no one else near me. The main thing is that they look great.
United States View Johnny225's Electric Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Which High Beam Lamps to use hyprblu Exterior 6 Jan 23rd, 2006 02:00 AM
Connecting PIAA driving lights - Which wire is the high beam wire? orbeamike Exterior 0 Jul 22nd, 2005 04:52 AM
Need Help: Changing High Beam c/m Exterior 1 Jun 19th, 2005 12:01 PM
High Beam / Fog Lamps scottinflorida General Discussion 3 Jun 1st, 2005 05:53 PM
How can I get the xenon HID High Beam? dinlo MINI Cooper S 25 Mar 19th, 2003 02:43 PM
