"Follow me home Lights" - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 23rd, 2004, 09:40 AM
Todd!'s Avatar
Boy who made the wolf cry
Send a message via MSN to Todd!
Local Time: 05:38 AM
Australia Male
I was wanting to activate the "Follow me home lights"... when you lock your car the lights stay on for a set period of time, blah, blah... cause my car doesnt have it, and it would be handy.
I looked through the FAQ's and I couldnt seem to find the instructions on how to do it.
I was wondering if it is something that you can do... or does your dealer have to do it for you?
I was also after instructions on removing the tail lights and high mount stop light to put clear ones in... I used the search FAQ function and only got vague answers...
Could someone send me in the right direction!!
Thanks in advance!!
Todd
PROJECT POLARIS - Die Wiedergeburt eines kultautos
Old Jul 23rd, 2004, 09:46 AM
basskiwi
Guest
Posts: n/a
On mine you just activate it as you would your main beam (Pull the light stalk towards you). If the key is out of the ignition then the headlights come on instead and go off after 40 secs or so.
I don't think there's an option to do it on lock.
Old Jul 23rd, 2004, 10:13 AM
Send a message via MSN to MickyD
Australia View MickyD's British Racing Green & White 1st Gen MINI Cooper S Profile
hey todd, they'll already be activated - they are on mine. once you've turned everything off just pull the stalk towards you like you're flashing your lights and they'll turn on.
Old Jul 23rd, 2004, 11:48 AM
Shaun's Avatar
Mr Big Stuff
Local Time: 08:38 PM
United Kingdom Male View Shaun's Pepper White & Black 2nd Gen MINI Cooper Clubman Profile
Really I thought you left the lights on switch off the ignition then turn off the lights.?
Then walk away looking over your shoulder making sure they go off.
Old Jul 23rd, 2004, 12:06 PM
Ady's Avatar
Ady
Tinkering In The Garage
Send a message via MSN to Ady Send a message via Skype™ to Ady
United Kingdom Male View Ady's Chili Red & Black 1st Gen MINI Cooper Profile
The older cars had it, my 03 model year Cooper had the old settings where they stayed in automatically. My 04 Model year Coop has the new ones you have to turn on using the stalk for main beam, it just depends on what age your car is
Ady
Old Jul 23rd, 2004, 03:02 PM
Shaun's Avatar
Mr Big Stuff
Ah I see
Old Jul 23rd, 2004, 03:22 PM
MINILLA's Avatar
Send a message via AIM to MINILLA Send a message via MSN to MINILLA
Local Time: 03:38 PM
United States View MINILLA's Pepper White & Body Color 1st Gen MINI Cooper Profile
Don't think the US cars have this option? anyone know?
Old Jul 23rd, 2004, 03:29 PM
vcullen's Avatar
Local Time: 02:38 PM
United-States
My 2004 Cooper, Ignition off , key out , pull flasher stalk, lights stay on apprx 1 minute.
Old Jul 23rd, 2004, 03:30 PM
MINILLA's Avatar
I'm July 2003 build. I'll have to check but I'm going to be surprised if its active.
Old Jul 23rd, 2004, 08:21 PM
MGB Boy's Avatar
puckstopper
Spain Male View MGB Boy's Chili Red & White 1st Gen MINI Cooper S Profile
It can be programmed. My car is a June 2002 build, and it has it. Lights on, turn off car, remove key, turn off headlights, exit car, lights stay on. When they are programming it, you can specify how long you want them to stay on, i.e. 30 sec, 60 sec, 90 sec...
-Ricardo
"2 minutes by yourself and...you feel shame, you know...and then you get free"
Old Jul 23rd, 2004, 08:44 PM
Fevs's Avatar
GEEEEEEEEK
England Female
AAAAAH thats how its done had it the old way on my 03 cooper couldnt figure out how it worked on my 04 S
saved me a trip to the dealers to look a fool
thanks
Global motivator
Old Jul 24th, 2004, 03:13 PM
huntmdwn's Avatar
Send a message via AIM to huntmdwn
Local Time: 01:38 PM
on the old coopers, what happens if you dont turn off the lights and you just
have lights on
turn off car
pull out key
exit
will the lights still go off?
Old Jul 24th, 2004, 03:56 PM
Paul's Avatar
MINI2 No.1
Local Time: 07:38 PM
England Male
Just about every MINI ever made has this option available, with different time limits. There's very few MINIs which cant have it, and I've no idea why not. Most can, and most dealers will do it. Some (still, sadly) just cant be bothered to even look, let alone change settings.
On cars build before Sept '03 it's a case of leaving the lights on, car off, lights off..... it's activated. Easy.
Cars after that date it's lights off, car off, flash lights.... it's activated. Not quite so easy.
If it doesn't work, many dealers will switch this option on for your FOC at service time/when in for warranty work. Some will charge for this to be done. Their privilage really.
Old Jul 25th, 2004, 04:32 AM
Todd!'s Avatar
Australia Male
Sorted!!
Thanks guys!! I knew the lights came on when I switched the stalk on... but always turned them off before they turn themselves off...
I have an 1974 BMW 2002, when you leave the indicators on, it lights up the head and tail light on that side of the car... til you turn it off, or until the battery goes flat
I had assumed by switching the headlights on, it did the same thing... My mum has a new Mercedes Benz and when you lock or unlock the car, the interior and exterior lights automatically come on for a set time, then switch off... I has assumed that the "follow me home" lights could be programmed to do the same...
Thanks again!! Most appreciated!!
Todd
What are "Follow Me Home Lights" monkeynuts First Generation MINI Exterior 16 Feb 25th, 2004 09:58 PM
Follow me home lights on 2004? mczinn General Discussion 7 Nov 20th, 2003 11:43 AM
"Follow Me Home" Lights? MarkW19 General Discussion 14 Jun 16th, 2003 05:21 AM
Follow me home lights moneypennyf General Discussion 8 May 8th, 2003 05:09 AM
Follow me home lights? eBrit General Discussion 7 Jul 21st, 2002 06:31 AM
