| The 116.5 bhp figure (don't forget the .5!) was only what the engine was pushing out. By the time this and gone through the transmission to the wheels, some of it has been lost due to friction and other such factors. This is about 26% in this case, don't know if this is good or bad. In essence, I guess you only feel what's at the wheels... ![]() Dom |
| In reality, everyone talks about BHP at the fly wheel anyway so no-one really cares what it is at the wheels. I don't think losing 26% through the transmission is all that bad as most cars lose a similar amount. What everyone seems to have ignored though is the torque... The Citroen Saxo VTS pushes out 120bhp (more on newer models), yet can only muster 107lb/ft of torque. The MINI has 122 lb/ft, so is excellent in that respect. Just need to up the bhp to match! Dom |
| A cold air induction kit and exhaust would all help, but would be best with an aftermarket chip. The differences between a unichip and a superchip would not really be noticeable on a standard engine. Indeed, the unichip really comes into it's own when mods such as cams have been done, as each chip is set up specifically for the characteristics of your engine. Cold air induction would help a bit, but the fan on the rollers was blowing air into the engine bay at the time so may have cooled it a little. Either way, if you're serious about power and not just sound, then a chip of some sort should be done! Dom |
| Dom, How can theY "read" flywheel BHP on a rolling road? OH, just for reference; The original Mini also lost are 26-28% of the power thru the gearbox. A straight-cut 'box would loose a bit less, somewhere between 21-25% depending upon the type of 'box. I have no sound figurs for 'dog boxes' but I would think they'll be close to SC/CR gears. "Life begins @ 7,000 rpm's" Last edited by ADO15; Apr 30th, 2002 at 05:07 AM. |
| A rolling road always measures output at the wheels. The flywheel figure is worked out mathematically. True flywheel power can only be measured on an engine Dyno which is usually done with the engine on the bench. At the end of the day it is the power at the wheels that counts, as this is what is put down onto the road. Also bhp is more about top end speed, whilst torque is about how quickly you get there. A high torque figure is only really useful if the torque curve is relatively flat. That means the engine gives nice progressive power making it more enjoyable to drive. Hope this helps ![]() Mon ...1996 Rover Cooper in Tahiti Blue with white...and rust. Chipped windscreen, blowing RC40 exhaust and cheapo spanner tyres... www.derbyminiclub.co.uk - THE club for Derby Minis |
| 1320 Autos One / Cooper Rolling Road Project | Paul@1320 | First Generation MINI Tuning | 30 | Jul 18th, 2008 10:21 AM |
| Rolling Road | Ven0m | First Generation MINI Tuning | 32 | Feb 25th, 2008 03:11 PM |
| Newbie and Rolling Road | harddrive | General Discussion | 1 | Mar 17th, 2004 06:18 PM |
| Rolling Road | James Haigh | First Generation MINI Cooper S | 3 | Feb 28th, 2003 01:35 AM |
