Favour from someone with Xenons and a Volt Meter - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 6th, 2004, 11:43 AM
aphix's Avatar
Send a message via MSN to aphix
Local Time: 10:33 PM
Hey Guys,
I have a favour to ask.
A few weeks back i fitted Xenon headlights to my 04 Cooper; anywho i get flicking for 5-10 seconds when i turn them on initially... they strobe in fact.
Cars fitted with Xenons have 2 addtional connections on the headlight connection, i need to confirm if one of these is an additional power supply.
All i need someone to do is to attatch a volt meter to this connector, and the other to the body and tell me if it regsiteres at 11v when the low beam is turned on.
I understand the xenons need to be programmed in but as far as im aware this is only for the DHL (and i dont have this as im not paing 800 squid for a wiring harness)
Rob
Old Sep 6th, 2004, 12:00 PM
Tonyt3's Avatar
Track addict
I don't think anyone should be messing around with anything to do with the xenons mate - BMW won't even change a bulb unless theres a properly qualified technician on hand. Theres a health and saftey issue here and only fully qualified BMW personel should attempt what you are asking - IMHO of course.
Old Sep 6th, 2004, 12:03 PM
ButtonIt's Avatar
www.totalmini*****
Send a message via MSN to ButtonIt
Local Time: 09:33 PM
England Male View ButtonIt's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View ButtonIt's Classified Ads
As far as I know, the voltages are different for Halogen or Xenon units? Don't quote me on that though.
Old Sep 6th, 2004, 12:08 PM
aphix's Avatar
The Xenons work off a 12v supply from the car. Nothing dangerous or fancy.
The only high voltages are after the ballast, which is why you shouldnt go near that area. Over 10,000 Volts. (everything dangerous is sealed out of harms way) the ballast needs to step the 12v from the car up to over 10,000v to get the burner to arc, then it requires less then 12v to keep going.
But the area im concerned with is about 11volts.
If nobody wants too then thats cool... i'll ask a breakers yard to do it.
Its the connection to the headlight that im interested in, its just a pull of clip.
Rob
Old Sep 6th, 2004, 12:10 PM
ButtonIt's Avatar
www.totalmini*****
Oh, sorry I thought you meant on the otherside. Yeah, I'll do a check when I get home if you like.
Old Sep 6th, 2004, 12:20 PM
aphix's Avatar
Thanks ButtonIt,
Heres the connector of the halgogen connector. Im not too interested in the top small pin, as im fairly sure thats for diagnostics or something.
Just the one with NC
Thanks for this
Rob
Old Sep 6th, 2004, 12:33 PM
LMB
...where´s the any-key?
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
Quote: Originally Posted by aphix
Hey Guys,
Rob
Would it not be easlier to pop to a dealership with a Voltmeter and ask them to do it?
What's with the magic 11v? Is this what yours reads?
Old Sep 6th, 2004, 12:37 PM
aphix's Avatar
Yeah possibly, it does no harm asking though.
I can only do it in a lunch hour and ive allready used it today.
No idea why it says 11, it seems to fluctuate from 11.4 to 11.7 and when their not on they sit at 3.33v
Rob
Old Sep 6th, 2004, 12:59 PM
SoggyCornFlakes's Avatar
total MINI . com
England Male View SoggyCornFlakes's Pepper White & Black 1st Gen MINI Cooper Profile View SoggyCornFlakes's Classified Ads
As with any electrical or mechanical work it can sometimes be safer to get a professional to do the job if you are not 100% sure of what's involved - it can also turn out cheaper in the long run sometimes !
Old Sep 6th, 2004, 01:03 PM
aphix's Avatar
In what respect?
Rob
Boost and Volt gauges Cooooooperslad First Generation Interior & Ice 1 Apr 27th, 2007 10:36 AM
Aftermarket Oil/volt guages? bloodyank First Generation MINI Cooper S 6 Feb 28th, 2005 02:22 PM
12 Volt Feed Restyle First Generation Interior & Ice 5 Sep 3rd, 2004 07:21 PM
2005 Xenons swappable with 2004 Xenons? TomH First Generation MINI Exterior 9 Aug 26th, 2004 10:57 AM
12 volt supply in luggage compartment andy_guildford First Generation MINI Cooper S 19 Jul 14th, 2004 11:05 AM
