Tips and Tricks For Driving a Manual - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 3rd, 2004, 03:37 PM
Local Time: 03:41 PM
Smile Tips and Tricks For Driving a Manual
I've had my 5-speed Cooper now for about 4 months and I feel like I've pretty well "mastered" everyday driving with it. But, I'd like to hear everybody's little tricks or techniques they use while driving a manual. Whether it's just something to get a smoother shift or something that most people don't know about - share it all here.
Old Oct 3rd, 2004, 03:50 PM
monkeynuts's Avatar
my ponies have escaped!!!
Local Time: 08:41 PM
England Male View monkeynuts's Classified Ads
i find if you havent got a camera in one hand and a walkie talkie in another, changing gear seems to be fairly easy
my knee hurts a bit tho
m o n k e y : n u t s
Old Oct 4th, 2004, 07:07 AM
Don't be scared of the handbrake for hillstarts.
54 Plate All Black Cooper S with Chilli, BoostCD, MFSW, Heated bits.
http://www.evoposters.net/carsb/album43
Old Oct 4th, 2004, 07:31 AM
Hat's Avatar
Hat
ITS RAINNIN' SIDEWAYS
England Male View Hat's Classified Ads
use the revs up to the limit - 2nd gear at 4500-6500 rpm is awesome
Old Oct 4th, 2004, 11:43 AM
Aqualung's Avatar
Sitting on a park bench..
United States View Aqualung's Indi Blue & Black 1st Gen MINI Cooper S Profile
I've found an interesting site, all about manual driving...http://www.standardshift.com
Old Oct 4th, 2004, 12:02 PM
the W'rkncacnter's Avatar
Chaotic Entity
Send a message via AIM to the W'rkncacnter
United States View the W'rkncacnter's British Racing Green & Black 1st Gen MINI Cooper S Profile
Here's directions for driving a stick as my girlfriend would write them:
1. Depress clutch
2. Shift into 1st.
3. Rev engine to 5000 rpm
4. Release clutch
5. Scream and then refuse to drive the car again.
Old Oct 4th, 2004, 02:08 PM
murwil
Guest
Posts: n/a
United-Kingdom
POne very good technique to practice (carefully) is that if you want to change down, say on a hill from 5 to 4, or 4 to 3, keep the throttle where it is (this requires a little discipline) then as quickly as you can hit the clutch, shift the gear and release the clutch without removing the foot from the loud pedal. The revs will go up of course as the clutch is depressed, but by then you will be in the lower gear and be letting the clutch back in. If you practice this carefully, you will master a smoothest, fastest down shift you can do...
MW
Old Apr 17th, 2006, 06:11 PM
r34ver's Avatar
Sergeant Pepper
Send a message via MSN to r34ver
Local Time: 07:41 PM
United Kingdom View r34ver's Pepper White & Black 1st Gen MINI One Profile
favourite gear? it's gotta be 2nd or 3rd. Completely unrelated however, why if you start the engine with the pedal down (in neutral) does it only rev to 3000 until you release and give it some again?
SGT Pepper
Old Apr 17th, 2006, 06:18 PM
minicabrio's Avatar
Soon to be deleted !!
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
Safety measure... so you can't start it in gear by accident at full throttle...
Also, the engine requires only a certain amout of throttle to fire, and doesn't want to be over-revved when cold.
Old Apr 18th, 2006, 12:49 PM
frylock's Avatar
Local Time: 02:41 PM
United States Male
Someone's already mentioned this, but I thought I'd reiterate. Rev matching your down shifts makes things a lot smoother. There's three methods of rev matching a down shift (that I know of):
1) Granny shift--Press and hold clutch. Shift down into desired gear. Press brake as necessary. Press accelerator until you've reached 3000-4000 RPM. Release the clutch. Enjoy a smooth shift. This is the easiest method, but not what you want to use on a sharp curve or an icy road--it's bad to keep the clutch held in under these conditions.
2) Double clutch--Press clutch. Shift into neutral. Release clutch. Brake as necessary. Increase engine speed to 4000-5000 RPM. Press clutch. Shift down into gear. Release clutch. Enjoy a smooth shift. This is a little more difficult, but you can keep traction to the tires in neutral. You need to rev higher with this method because you will lose revs while completing your second shift.
3) Heel to Toe--Just like a double clutch, except you press brake with the toe of your right foot and accelerator with the heel of your right foot (not simultaneously!!!). This allows you to shift more quickly than a double clutch so you don't have to rev the engine so high.
Admittedly, I'm no expert. I'm mostly a granny shifter. Sometimes I'll try one of those other shifts during the winter on an icy curve.
Driving manual with useful tips Bmx 777 MINI in the Media 0 Dec 12th, 2006 08:55 PM
Tips for newbie manual driver tshizzle First Generation MINI Cooper S 6 Apr 30th, 2006 09:53 PM
Getting a new MCS in January... need help/tips/tricks...etc !! 8valveVW First Generation MINI Cooper S 5 Dec 30th, 2005 09:30 AM
Manual trans driving tips? dave316 First Generation MINI Cooper S 7 Aug 1st, 2004 01:35 PM
Any tips for a new manual driver? dSpotter General Discussion 53 Feb 2nd, 2003 06:36 AM
