| Flat Towing Mini-- does mileage accrue? Does anybody know if the odometer will continue to accrue miles on a Mini when it's flat towed (on all four wheels) behind an RV? Some cars do, some cars don't, and on some cars the odometer can be easily disabled by pulling a fuse. Just wondering which category the Mini falls into. (Yes, I'm aware that the factory sez you shouldn't flat tow a Mini). Thanks, Denny |
| Oops, never mind-- found my answer on one of the RV forums: "I have been towing it for the last two years and it does just fine. I called Mini before towing it and I was told that I would have no problem. The key needs to be in the Acces. position and it does not gain miles on the odometer." |
| Only cars with mechanical odometers (cables connected to wheels, drive shafts ) accumulate mileage when being towed. Most of those systems went the way of the dodo...... |
| >> Only cars with mechanical odometers (cables connected to wheels, drive shafts ) accumulate mileage when being towed. << Not exactly. In order to be towed behind an RV, the steering lock has to be unlocked. On many cars, that means towing with the key turned to a position that also energizes the electronic odometer circuitry-- so those cars continue to accumulate miles under tow. On cars where that's a problem, it's often possible to pull a fuse prior to towing that will disable the odometer circuitry. Denny (who has little experience with Mini's-- but lots of experience towing other cars with RV's <g>) |
| Towing a MINI | Beau | General Discussion | 15 | Apr 13th, 2008 05:24 PM |
| towing MINI on a flat bed? | Toddodie | General Discussion | 3 | Jan 29th, 2006 11:53 PM |
| Mini Towing | ruggiero | General Discussion | 1 | Aug 17th, 2005 12:05 AM |
| Towing with your Mini | Esser | General Discussion | 5 | Aug 10th, 2005 08:30 AM |
| flat towing a mini | groeshl | General Discussion | 1 | Apr 24th, 2003 12:18 PM |
