| MINI2 Regular | What is TLC? I've search and can't find an explanation - is it the free service 3/36k? |
| MINI defector Join Date: Mar 2002 Location: Harefield Local Time: 10:43 AM
Online | It's a UK thing. £100 for servicing. BMW have this on all their new models ![]() MINI, RX8 and MX5 - Done those............. It's now TTime ![]() ![]() Unofficial MINI2.com bean counter |
| | #9 (permalink) |
| MINI2 Regular | This is what I find on the US site: MINI Engine Oil Service Change oil and oil filter while engine is at operating temperature. We recommend MINI Synthetic Motor Oil, p/n 07 51 0 143 829 Replace microfilter. Note: reduce replacement interval in dusty operating conditions. Check overall thickness of front and rear disc brake pads (outer pads only) using special tool. If replacement is necessary: Examine brake disc surfaces. clean brake pad contact points in calipers. Grease wheel centering hubs. Check thickness of parking brake linings only when replacing rear pads. Check parking brake actuation. Adjust if necessary. Reset Service Interval Indicator Note: Do not reset Service Indicator when additional oil changes (between the normal intervals) are requested by the customer. MINI Inspection I Undercarriage Change oil and oil filter while engine is at operating temperature. We recommend MINI Synthetic Motor Oil, p/n 07 51 0 143 829 Check transmission for leaks. Half shafts: Check for leaks at flexible boots. Visually check fuel tank, lines and connections for leaks. Check condition, position, and mounting of exhaust system. Examine for leaks. Check power steering system for leaks. Check p/s fluid level; add fluid if necessary. Check overall thickness of front and rear disc brake pads (outer pads only) using special tool. If replacement is necessary: Examine brake disc surfaces. clean brake pad contact points in calipers. Grease wheel centering hubs. Check thickness of parking brake linings only when replacing rear pads. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc. Check brake system connections and lines for leaks, damage, and incorrect positioning. Check parking brake actuation. Adjust if necessary. Check all tire pressures (including spare). Correct if necessary. Check condition of tires (outer surfaces [left/right]), tread wear and pattern; in case of uneven tread wear readjust wheel alignment if requested(to be invoiced separately.) Note: If requested rotate all four road wheels as instructed and rebalance. (invoiced separately.) Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years). Engine Compartment Read out diagnostic system. Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary. Note: Coolant must be replaced every 4 years (time interval begins from vehicle's production date). Check level of brake fluid in reservoir. Add fluid if required. Replace brake fluid every 2 years (timing interval begins from vehicle's production date).* Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary. Check air conditioner operation. Replace microfilter. Note: reduce replacement interval in dusty operating conditions. Reset Service Interval Indicator. Body/Electrical Equipment Check battery state-of-charge, and charge if required.* Check lighting system, i.e., headlights, foglights, parking, back-up, license plate, interior, glove box, illuminated make-up mirrors, luggage area lights. Check instrument panel and dashboard illumination. Check all warning/indicator lights, check control. Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch. Check windshield and tailgate wipers and washer systems; wiper blades, washer jet positions. Check condition and function of safety belts. Check central locking system. Check operation of all latches. Check heater/air conditioner blower fan, rear window defogger. Check rear view mirrors. Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories. Final Inspection Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission. Visually check shock absorbers for leaks. MINI Inspection II (same as I) |
| Changes to MINI TLC & TLC XL | Scrogg | General Discussion | 59 | Jul 24th, 2008 06:35 PM |
| What does MINI TLC & TLC XL Cover | Solwood | General Discussion | 1 | Oct 10th, 2005 09:22 AM |
| Tlc | NeilF | MINI Cooper S | 11 | Mar 5th, 2004 02:40 PM |
| TLC... What and how much? | Beester | General Discussion | 1 | Jul 3rd, 2003 09:16 AM |
| Anyone NOT got TLC!? | MiniOnd | General Discussion | 18 | Apr 15th, 2003 07:19 AM |
