| Toy Kahuna Join Date: Jun 2003 Location: Rhode Island Local Time: 06:44 PM
Offline | How to hardwire a detector? Hi, I want to avoid using the cig liter. I have a red and white wire. Do I connect the red to the 15 amp lighter fuse and the white to ground? Do I still need to use the fuse inline? Thanks, PinCity 03' EB MCS Wh/Wh Webb Sports Modified |
| MINI2 Senior Join Date: Apr 2004 Local Time: 11:44 PM
Offline | Red to +ve sounds right. You should have an inline fuse as the 15A fuse for the cigar lighter is too much and if the detector shorts the wire will get very hot before the fuse goes. You only need about 1A to run a detector so a 1 - 3 A fuse should be fine. The mini cigar lighter turns off (mine doesn't any more, 'cos I changed it) when you turn off the ignition, which is probably what you want. |
| MINI2 Master | Hey pin--I have instructions on the right way to wire it in to the fuse box: http://www.jwardell.com/mini/fusetap.html If you search the forums you will also find many others discussing how they did theirs, many tapping the power for the visor light or clock. |
| V1 Hardwire on an 05 | zerofighter | Interior & Ice | 3 | Mar 20th, 2005 05:43 AM |
| How'd you hardwire your V1? | Aqualung | Interior & Ice | 7 | Mar 22nd, 2004 04:40 PM |
| hardwire radar | neck | General Discussion | 0 | Oct 27th, 2003 03:43 AM |
| Geodesy Hardwire Install | Simon_K | Interior & Ice | 5 | Dec 5th, 2002 05:56 AM |
| Which Radar Detector? | minimc | Engine & Drivetrain Tuning | 10 | Nov 13th, 2002 11:32 AM |
