| I got my '91 celica changed from an auto to a manual and the manual that was put in always crunched third gear. I had always driven manuals, so I was sure that it wasn't me. I had it looked at and it was found that the gearbox was stuffed (it was second hand anyway). I'm not very good when it comes to gearbox internals, but it definitely sounds like there is something wrong with the gearbox. Try to get someone else to drive it and see if they crunch third. If they do it, then take it to the dealer and make them aware that there is a problem with the gear box. You don't crunch any other gear, do you? So why would it be driver error? Cheers Dutchy. Sadly INIMINI is gone, but never forgotten. |
| syncro Sounds like its the transmission. My old VW did this in 2nd gear only, the mechanic said it was the syncro gear. Once the transmission was rebuilt the problem went away. I assume it is under warranty, then I would get on record with the dealership about the problem. Thanks my 2cents. Later. |
| mini vanilli, Do you tend to shift fast, or do you shift more slowly and allow the synchros time to do their job. If you are a fast shifter you might have bent one of the shifting forks inside the transmission. Of course, you could have a bad transmission. A trip to the dealer is in your cards. Take one of the service writters for a test drive to demonstrate the problem, then have him drive to experience the same problem. Motor on, Dudes and Dudettes!!! '06 MCS SB/S '02 MCS DS/W (retired) |
| Do MINIs have hydraulic clutches? If so, the fact that you can shift into third after pumping the clutch, points to moisture / air in the line. A good flush and bleed may do it. But the fact that this only happens in 1 gear would seem to point away from this. But it's easy and cheap to do so I would give it a shot. The other possibility, based upon only occuring in 1 gear and accompanied by a "grinding" noise, is a failing synchronizer on that gear. Hope it's not this as repair reguires dismatling the gearbox. As a temporary "fix" you could double clutch whenever changing into the offending gear. Good luck. Tom [ |
| Your 3rd gear synchro ring (made of brass) is probably trash. The only other thing that it could be is that the cable(s) that actually shift the gearbox are worn. Cables=cheap repair and you should do it, synchro will be BIG money though the part itself costs very little. |
| REAR WINDOW SHATTERING FAULT - dealers aware of fault | Mini Virgin | First Generation MINI Convertible | 161 | Feb 14th, 2012 12:02 PM |
| Fault with some minis BMW won't admit- Rapid & uneven tyre/tire wear | Geese | First Generation Faults & Fixes | 1 | Dec 20th, 2004 01:12 PM |
| Fault After Fault - At Wits End! | COOPERUK | First Generation Faults & Fixes | 6 | Oct 13th, 2003 12:03 PM |
| It's all my fault! | ches | General Discussion | 19 | Sep 16th, 2003 03:02 AM |
| 7 MINIs - 100% Fault Free | BRGreenie | General Discussion | 18 | Jul 1st, 2003 07:28 AM |
