| List of Programming Options (Memory Options) Does anyone have the list of programmable options with an explanation of what each on is? My dealer has never heard of the "Make Waiting Fun" program, and the accompanying e-mail that asks you how/which options you'd like programmed. There is an FAQ on this forum, but it doesn't have explanations, so I don't really know what I'm opting for! Thanks! |
| Hi not sure if this is the list you are after but i found it on the diy page of this site. it is a list of memory options you can have programmed into your car. hope this helps What 'memory' options can be programmed into my MINI? Different activating signals to confirm that the vehicle has been locked/unlocked. (Seems on early builds only) Deactivating the headlight courtesy delay function (AKA 'Follow me home lights'). With 40, 90, 150, 240 second delay options. Switching on the inside light via the remote control. (Unconfirmed as an option, standard on unlock via remote). Activating / deactivating the interior movement detector/tilt alarm sensor via the remote control. (Available by 'double locking' but not recommended for insurance and security purposes). Automatically locking the vehicle after setting off. Stop function of window lifts when opening/closing. Selective central locking where the first press unlocks only the drivers door, then the second press unlocks the remainder of the vehicle./Selective Central Locking with key in door lock. Holding RC down options: Unlock Boot, Comfort Opening, or nothing. (Remote comfort opening, not on all vehicles). Windscreen Wipers. Switch back when stationary, active or not active. Automatic door unlock with ignition off. Speed sensing wipers (n/a with rain sensitive wipers factory option). Locking when engine is running (with second key) . Activating/deactivating daytime driving lamps. Power sunroof - 1 touch open and/or close. Power sunroof - 1 touch raise Park Distance Control Loudness in back Park Distance Control System OK signal on every activation Rain sensor Threshold settings The main thing to do here is ask your dealer for a list of options for YOUR car, they can plug it in and tell you in a matter of minutes. http://www.mini2.com/forum/faq.php?f...faq_faq_memory |
| There's a thread about tis with good info at North American Motoring: http://www.northamericanmotoring.com...t=programmable It includes the post with the file version of the programmable option checklist PDF: http://www.bergin.us/MINI_Programmable_options.pdf Hope this helps! _Dave_ |
| memory options | GirlyMini | First Generation MINI Cooper | 1 | Apr 20th, 2007 05:53 PM |
| What programming options do we have for our Mini? | usaminicooper | First Generation MINI Cooper S | 12 | Apr 1st, 2005 12:16 AM |
| Programming Options when ordering (UK) | Texy | General Discussion | 11 | Jun 27th, 2004 09:02 PM |
| Memory Options | Griffy | First Generation MINI Cooper | 4 | Jan 7th, 2003 04:00 PM |
| Programming Options | KenL | General Discussion | 8 | Jul 31st, 2002 01:16 PM |
