Spot Lamp Wiring Advice Required Please? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 14th, 2005, 03:38 PM
J0nesy's Avatar
Back on the Road
Local Time: 09:56 PM
United Kingdom Male View J0nesy's Dark Silver & White 2nd Gen MINI Cooper S Profile
United-Kingdom Spot Lamp Wiring Advice Required Please?
I have just been trying to wire up some new spot lamps, my question is, on the headlamp cluster there are 3 different coloured wires, brown, white/green and yellow & green. This is how I interpret them.
Brown = Main Beam.
Yellow/Green = Earth.
White/Green = Headlamp.
Is the above correct? If not can somebody please help.
I tried using the brown wire because I want them to come on when the main beam is activated, but no joy,
Can somebody please shed some light.
Dave.
Old Aug 14th, 2005, 04:15 PM
Rayman's Avatar
"Buying and selling"
Send a message via MSN to Rayman
Local Time: 10:56 PM
United Kingdom View Rayman's Indi Blue & White 1st Gen MINI Cooper Profile
Hi, i have a set of spotlamps here beside my PC, if i open one up and take a pic will that be any help to you?
2001 cooper (sold)
1995 Supra RZ-S TT auto in white.
Old Aug 14th, 2005, 04:59 PM
J0nesy's Avatar
Back on the Road
United-Kingdom
Not really but thanks anyway.
I have fitted the lamps it was just a case of how to wire them into the headlamps, I could do with somebody confirming the which wire is which.
Dave
Old Aug 14th, 2005, 05:23 PM
Squire's Avatar
oohh that was a good one
Send a message via MSN to Squire
England Male
uumm i had a set of spotlamps installed and was told that to get them working when the main beams come on then you have to do something with the ECU....ie you had to take it to a dealer or another company who had access to a laptop which can be plugged into the mini's computer and set them up.....don't ask me why, but i was told by both minimania who fitted them for me and the bmw dealer that this was the case
so i'm guessing you need to install em and then take it somewhere to get the ECU configured for it
Old Aug 14th, 2005, 05:27 PM
Rayman's Avatar
http://www.mini2.com/guides/pdf/Driving_Lights_9__.pdf
Will this help at all. I also read that the official mini lights need programming by the dealer to get them to work.
2001 cooper (sold)
Old Aug 14th, 2005, 08:11 PM
tnoy66's Avatar
POP..POPPOP..POP
Online
England Male View tnoy66's Pepper White & Black 1st Gen MINI Cooper S Profile View tnoy66's Classified Ads
Firstly, what or which make of lamps are they
Just dug out my Hella instructions and it says to tap into the BLUE/YELLOW, which you don't mention
Brown is earth.
Old Aug 14th, 2005, 08:33 PM
SteveM3's Avatar
I think, but not very often, that brown is earth, white/green is high beam and yellow/green
is low beam (dipped). I don't really understand all this programming needed malarky as
at some stage a good old fashioned hot wire must go into the headlamps. The wires you
have discovered I believe to be post module control unit. So I can't see why you can't use
the white/green to activate a relay for power to the spots. Don't try this just yet though,
someone may turn up a wiring diagram for non-BMW spots that do something similar.
By the way I am not criticising those who told you about the programming needed as
they are correct for the official version.
Old Aug 15th, 2005, 03:49 PM
J0nesy's Avatar
Back on the Road
United-Kingdom
Right, thanks for the info guys.
I have managed to determine that the brown is earth, green/white is to the headlamp & the green/yellow is the main beam. The thing that confused me was the usually here in the UK Green/Yellow = Earth, But obviously this is not the case here. Anyway I have to wire the spots into the headlamp and sidelights, I am using a relay and instructions provided with the kit i bought on ebay. http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
I should hopefully have some pics soon. I think they look
Dave,
Old Aug 15th, 2005, 07:06 PM
J0nesy's Avatar
Back on the Road
United-Kingdom
Just 1 more question.
Their are 2 wires that go into the sidelight, blue & brown. I have wired the spots up to the main beam, but you can also wire them up to the sidelights, Is Brown Earth? It would make sense because on the headlamp cluster the Brown was earth, Can somebody please confirm this?
Thanks.
Dave,
Old Aug 15th, 2005, 08:04 PM
tnoy66's Avatar
POP..POPPOP..POP
Online
Can't wait to see the pics of these
The green/yellow coding for earth only applies to mains (240v) wiring.
The brown is the earth. There are several places on the MINI where lots of brown wires meet on a big plug, they are just earth wires meeting at the same point.
Old Aug 15th, 2005, 08:22 PM
J0nesy's Avatar
Back on the Road
Cheers Fella.
I just took a quick photo, Not the best but their will be better ones to come.
Old Aug 15th, 2005, 11:33 PM
SteveM3's Avatar
Blue/yellow left and blue/green right. Using these doesn't make sense as that will have the
spots on all the time at night. I don't think people coming towards you will like that. Leave
them as they are on main beam.
Old Aug 16th, 2005, 07:29 AM
J0nesy's Avatar
Back on the Road
The spots have 2 bulbs, 1 for main beam brightness and another "halo" one that can be used with sidelights (the rim of the spot light illuminates only nothing like as bright as main beam)
I am going to wire them up to the sidelights today so I will keep u posted.
Dave,
Old Aug 16th, 2005, 11:00 AM
J0nesy's Avatar
Back on the Road
United-Kingdom
A few more pics.
ID:	97354   Click image for larger version
ID:	97355   Click image for larger version
ID:	97356   Click image for larger version
ID:	97357   Click image for larger version
  #15 (permalink)
Old Aug 16th, 2005, 11:03 AM
J0nesy's Avatar
Back on the Road
United-Kingdom
:d
ID:	97360   Click image for larger version
ID:	97361   Click image for larger version
ID:	97362   Click image for larger version
ID:	97363   Click image for larger version
Spot lamp fitting help dreadbones First Generation MINI Exterior 24 Nov 23rd, 2007 10:11 AM
Spot Lamp Covers Catskins First Generation MINI Exterior 11 Apr 21st, 2007 12:20 PM
Driving lamp wiring? fcarrano First Generation MINI Exterior 3 Jul 12th, 2005 04:40 PM
Spot Lamp Vibrations - Help? matt1584 First Generation Faults & Fixes 1 Jun 1st, 2005 01:49 PM
spot lamp kit... rinos69 First Generation MINI Exterior 7 Nov 15th, 2003 03:09 PM
