Mighty Stripes
Old Dec 8th, 2007, 09:17 AM   #1
roland2003
MINI 2 Sponsor GT Tuning
Local Time: 10:18 AM
Online
GTT Stage 4 Head ..50bhp increase?
Weve just had a look at some of the power gain or outright power of a couple of cars with GTT heads, and thought we would put them up to see.
-Our (standard SC) 'GTT260' demo car on GTT Stage 2 head (uses stock size valves) ..273bhp (240WHP).
-Tony Fenners car with GTT Stage 3 head ,stock intercooler, 17% pulley .....from memory the head gained 35+ bhp. compared to pre head power runs.
And Finally Alans GP . This went from 211bhp to 252bhp (still std intercooler) with the addition of just GTT Stage 4 head, Shrick cam, and going from 15% pulley to 18%. (also the required GTT fuelling mods ) ...Thats 41 bhp increase. Although a colder day the Din70020 correction should adjust accordingly therfefore the ambient temp should make no difference to the figures achieved.
Theres one other thing overlooked .....those increases are 'on top' of a GP head! which already has larger exhaust ports. If the car had been on a standard MCS head , that increase may well be over 50bhp.
Lees 'GTT300T' with the addition of GTT Stage 4 head and Shrick Cam achieved 391bhp.
Remember this is a customers car, headwork more than any other product can vary . Even with CNC machining theres huge amounts of hand fettling. Heres the proof that our production heads are every bit as good as our 'demo/own car heads.
-CNC Milling is our Forte......thats my original trade.I might do a technical thread on the CNC milling we use on our heads,...theres CNC milling (no big deal tbh) and theres GTT 3D milling (ports ,throats, & valve seats )
Old Dec 8th, 2007, 09:35 AM   #2 (permalink)
Aberdeen Al
Aberdeen Al's Avatar
Vroooom Vroooom
Old Dec 8th, 2007, 10:02 AM   #3 (permalink)
Hyper Active
Banned
Hyper Active's Avatar
This might be a silly question , but if a GTT Stage 4 head is put on a standard 170bhp MCS, would it then be running at 220bhp ?.
England Male View Hyper Active's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 8th, 2007, 10:07 AM   #4 (permalink)
Aberdeen Al
Good question.........
Vroooom Vroooom
Old Dec 8th, 2007, 10:21 AM   #5 (permalink)
roland2003
Online
I could produce a GTT Stage 4 head that would produce 50bhp gain on a stock MCS .
Actually that 'Special Stock Pulley Head' would not be suitable for a pullied car but would look mighty impressive for publicity.
Hows it done? .....Simple you just increase the CR at the same time,run some high octane fuel and as long as your still running stock pulleys 50bhp increase from just a GTT head on a 163/170 bhp standard car is definatly possible. That head would be hopeless with a small pulley though so you wouldnt sell it to someone as they would probably want to change pulleys and use pump fuel causing it to detonate/blow up .
A 'genuine' production Stage 4 head (capable of small pulley use etc) I would guess around 200bhp, but this is not the best /most cost effective power route to go.
Old Dec 8th, 2007, 10:33 AM   #6 (permalink)
roland2003
Online
One other thing regarding our Stage 4 heads. We are fortunate enough to have just bought a large quantity of BRAND NEW MCS heads. Therefore our Stage 4 heads will no longer be on exchange . You get to keep your old head ,plus you can be safe in the knowledge your 'new' gasflowed head has not been torn off someone elses car and just cleaned up to look new.
Old Dec 8th, 2007, 10:37 AM   #7 (permalink)
alski
100 bhp over stock,
alski's Avatar
stage 3 and 4 whats the difference, valves?
carefree
Old Dec 8th, 2007, 10:51 AM   #8 (permalink)
roland2003
Online
Yes Stage 3 uses Ultrik valves. Stage 4 Uses Shrick .
Ultrik are cheaper and smaller and what many 'big valve' heads use. The Shrick Exhaust valve we use is 2.8mm larger in diameter than stock.(that is BIG) .
But the GTT CNC milled seat and throat ,...thats even bigger!
5mm bigger in diameter than stock to be exact .
If you calculate the increase in cross sectional area of the Exhaust valve seat internal diameter or the throat..... thats an increase over stock of 63%.
Old Dec 8th, 2007, 11:27 AM   #9 (permalink)
Jaw_F430
Jaw_F430's Avatar
How much is a stage 4 head then? And what would be the additional cost to add a camshaft at the same time as swapping the head?
How much difference does it make from 15% pulley instead of 18%? As I run a 15% pulley
Regards
James
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 8th, 2007, 12:08 PM   #10 (permalink)
roland2003
Online
Outright purchase on brand new GTT stage 4 is £1295+vat. (excluding fitting)
When fitting any GTT head if were supplying the cam aswell then theres no extra fitting charge for this. We would advise GTT 440cc injectors & GTT Adjustable FPR at the same time. (Thats what Alans car has).
We can run it with either the 15% on its own or add the GTT +3% 2 piece alloy crank pulley,this gives equiv of 18% plus reduced rotational mass as it weighs only 1 pound aginst 5.5 or 7 pounds for the stock item. You can even purchase the GTT crank pulley wheels seperate from the sleeve part ,allowing changeover of diameter crank pulleys in about 15minutes . (if the inner arch is left out. temporalily) .Therefore we can try 15/16/17/18% if necessary.
Old Dec 8th, 2007, 12:20 PM   #11 (permalink)
Jaw_F430
Jaw_F430's Avatar
How much are the 440cc injectors and GTT Adjustable FPR, I have 380cc injectors at the moment would the cost be on exchange basis or would I keep the 380cc?
I am just trying to work out my next mods which at the best value for money and might as well go for a stage 4 head instead of getting a stage 2 which I was going to go for
Regards
James
Old Dec 8th, 2007, 12:24 PM   #12 (permalink)
Ant FR
Online
Ok, Roland does this answer the PM I sent you yesterday, does that mean wilcox head plus GTT cam, would be 1085 + VAT fitted ????
Old Dec 8th, 2007, 03:02 PM   #13 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Old Dec 9th, 2007, 08:25 AM   #14 (permalink)
roland2003
Online
1320 .. As requested by the moderators could you please give us 'space' (ie less interference)to promote our products and achievments on our threads...cheers.
Just to confirm:-
The GTT273bhp (240whp) was 'only' using our stage 2 head which uses standard valves. We did change to a GTT Stage 4 a couple of weeks before removing the car from the road for the GTT 300T project (which was just over a year ago) I.would say the power gain was quite noticable on top of the above figures but not dynoed at this point . There are graphs on the other thread to prove the 273bhp.
The '35bhp gain' on GTT Stage 3 head was Tony Fenners (Fone). I dont think the graphs were ever put up but hes certainly not in the habit (or have reason )to lie. Maybe he will if he sees this thread.
The 41bhp gain (over a GP head ) was Alan Whites (Snowie) . This was at the Surrey RR day. ...252bhp ,whereas previous to the GTT Stage4 head/cam ,extra 3% on the pulleys and a tweak from us on the GTT Adjustable FPR , it achieved just was 211bhp n the same RR. This was the highest power MCS there on the day ,beating a tuners own car aswell. We were very pleased with these results, expecially as there are still areas of this car still to be modified if the wife lets him.
ps Ant..... I'll work out a price for you tommorow.
Old Dec 9th, 2007, 08:55 AM   #15 (permalink)
roland2003
Online
Ok, I wasnt dead sure on that one. Good result Graham. As I said Alans still hasnt got a full house of mods yet like yours, he runs stock rev limit & map.
Regarding the various different stages of heads we offer, there are fundamental differences between them both in the areas that are CNC machined ...eg just the ports, or ports + throats, or ports+ throats+seats. Also the valves we use . ie stock or Ultrick or Shrick.
Always ask what make & size are used. The Shricks are about 3 times the price of Ultrik hence the use of them in our top head. Also ask what diameter the inside of the seats & throats are opened upto.?.... This is even more important than the valve size itself . Also find out how much and how far the fettling and knife edging of the port divider extends to. This is alot of work that you cannot do so well on the CNC ...its tempting to leave this out or reduce the effort in this area but not us even on GTT Stage 1 head.
Old Dec 9th, 2007, 09:10 AM   #16 (permalink)
roland2003
Online
Good, so when you put Jans head & remap on we will all expect to see on the Surrey RR centre
about 280-290bhp (ie 40-50bhp increase over the 241bhp standard head figure you got). Ok the cam is already in but your going to map it instead. Alans car didnt even need a rev limit increase.
-Please continue on the relevant thread or start a new one....
Old Dec 9th, 2007, 10:19 AM   #17 (permalink)
roland2003
Online
Funny how I knew you would not want to use your 'stock head' car as the baseline for demonstrating the increases of Jans head.
Oh well youv'e got to explain how other cars (with good leak down results on a stock head) of the same spec as yours eg GRS,Janspeed, Cam, 380 injectors any no other mods , cant get 241bhp on the Surrey RR that youve got . They should be able to get 280-290bhp on the Surrey RR then when they put Jans head on.
As I say can you not 'cloud' my thread any more ...cheers.
Old Dec 9th, 2007, 11:07 AM   #18 (permalink)
Hyper Active
Banned
Thanks for the reply . Although as a special it might be good for publicty, it would make for a rather dead end mod then if normal mods couldn't be added to it.
Although you mention that the production Stage 4 Head wouldn't be a cost effective mod on it's own, the JCW 210 kit does include a modifided head, that no dout is the reason for it's high cost . What sort gain do you think you would see if your Stage 4 Head was put on a JCW, that had no other mods and lets usume it is making the stated 210 bhp ?.
Old Dec 9th, 2007, 11:48 AM   #19 (permalink)
roland2003
Online
Hi, Alans car is the nearest weve seen to that test ,his stock GP made 203bhp.,
Old Dec 10th, 2007, 07:18 AM   #20 (permalink)
Snowie
Snowie's Avatar
Local Time: 09:18 AM
Online
Hi Bigshow and Loui
There is certainly more to come.
Remap is planned to make the most out of the 450 cc injectors - we are sure my GP can run with more advance and it is also rich low down
JCW exhaust is an issue with the flat spot just before the Y section - not sure how to resolve this at the moment and remain stock looking, Trying to find a JCW back system without the flat section.
Intercooler has been debated back and forwards so we tried a GRS at SRR - boost was up but BHP and Torque were the same, however we are sure that in hot weather GRS would be better than GP BUT and again I want the stock look.
Graham & Roland
Yes Graham's car was the highest BHP at Surrey Rolling Road (over 254) but was not the quickest on the road using Bigshows box of tricks.
Alan
In Italy
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
M7 Cosworth Stage 2? Glenns0245 Engine & Drivetrain Tuning 24 Jun 13th, 2006 01:32 PM
head gasket / knackered head arrgh welsh_willo Faults & Fixes 0 Feb 3rd, 2006 09:38 PM
MiniMania.com Stage 3 MINIdreamin23 MINI Cooper S 3 Nov 19th, 2004 04:44 AM
head unit causing my head to spin!! kars Interior & Ice 10 Oct 29th, 2003 03:54 PM
stage 2 head on mini one? williams1 Engine & Drivetrain Tuning 1 Jan 29th, 2003 02:53 PM
