Old Dec 17th, 2007, 12:54 PM   #1
Perm
Perm's Avatar
Local Time: 10:10 AM
Why is GTT turbo MCS have so much BHP vs the BMW units ?
Hi,
Can someone explain in a non technical way how BMW only manage to get 190 (ish) BHP from MINI Cooper S Turbo, whilst GTT can get 280 – 300 BHP ?
I know that engines are different, but they are both 1.6 litre units…… is there something fundamentally different about the two engines ?
What makes the GTT’s conversion so much more powerful than the BMW version ???? What does the BMW Turboed engine do wrong ?????
Perm
Old Dec 17th, 2007, 01:21 PM   #2 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Online
Hi Perm, BMW havnt done anything wrong. There are many reasons why BMW Mini R56 Turbo is only 190bhp. ..Cost, turbo sizing, head & cam, turbo manifold design,boost , and probably the need to hold back to enable a higher output version to be released later. The R56 turbo is very very small. IMO even too small for what I believe they wanted to achieve. The turbo unit in the GTT300T is rated at 360bhp by Garrett. The GTT intercooler/ cylinder head/manifolds we designed and use ,mean 400bhp is possible from our GTT300T 'base' . Bigger turbos (everthing else being specced accordingly) will produce more power but sacrifice low end and induce more lag. The R56 turbo I would hazard a guess that about 220bhp is the max it will produce. The plus side of the R56 is has splendid low down torque, the downside is it runs out of puff easily. The GTT300T realy is spot on for road & track, or if you want even more low end bias ..the forthcoming 280Tqs.
Old Dec 17th, 2007, 02:18 PM   #3 (permalink)
Perm
Perm's Avatar
Roland,
Thanks for the reply….. like others….. I have put on hold any plans of buying a R56 turbo until I see what the costs of the 280T comes in at…….
[ One additional question….. would the 280T conversion work well with an automatic gear box MCS ]
Perm
Old Dec 17th, 2007, 04:09 PM   #4 (permalink)
Tigger, Eeyore & Roo
May '08: Bye bye Mini2...
Tigger, Eeyore & Roo's Avatar
Over a year after launch and there still hasn't been a significant increase in power available on the '56 turbo Do you think that there might be a significant limitation in the basic engine or gearbox design that makes it unviable to increase its standard power output significantly?
May '08: Due to certain recent events on this site, I no longer wish to continue posting on Mini2. Such a shame after 4 otherwise very happy years on here
If you are a friend, I can always be contacted here!
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 17th, 2007, 04:52 PM   #5 (permalink)
roland2003
Online
Old Dec 17th, 2007, 05:23 PM   #6 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 02:10 AM
Probably why the factory Works will have a larger turbo
Old Dec 18th, 2007, 11:14 AM   #7 (permalink)
Yes.
That was said with feeling
Old Dec 18th, 2007, 11:52 AM   #8 (permalink)
Japper
Japper's Avatar
You're not looking in the right places then
There is a company out there with aftermarket parts producing proven gains of around 60hp. In addition a replacement turbo package available early next year producing around 300hp.
06 HB/W MCS Chilli
Scotland View Japper's Pepper White & Black 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Dec 18th, 2007, 12:27 PM   #9 (permalink)
I've yet to find them. Can you provide a link?
Also, from what I have read, the engine's standard torque output is pretty near the maximum specified load of the standard gearbox. Can anyone confirm this one way or the other?
Tigger.
Old Dec 18th, 2007, 12:39 PM   #10 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
With a turbo car your only cheap power replacements are manifold, exhaust, intake. Once you have done them maps and head work are the only other things really.... then your onto increased size turbos.
Tuning the R56 is difficult as the stock turbo is pretty weedy so your pretty limited IMO. The best option save some wonga and buy a bigger turbo. probably the simplest way forward as the engine is reasonably strong i would think...just the actual turbo thats the major limiting factor.
Old Dec 18th, 2007, 03:10 PM   #11 (permalink)
Japper
Japper's Avatar
Tigger.
You have PM
06 HB/W MCS Chilli
Old Dec 18th, 2007, 03:25 PM   #12 (permalink)
Snowie
Snowie's Avatar
Local Time: 09:10 AM
Online
I think the big question with the R 56 is - will the bottom end take the strain of the additional power ???
Inside sources indicate a few failures at high power figures - some say the limit of the bottom end is circa 220 BHP
Motorsport guys are questioning the potential longevity of the new R 56 race car. How many R 53 race cars have had engine failure - not many and those that have failed have mainly been due to cat failure (caused by the flexi breaking up and blocking the cat) causing cylinder overheating and piston failure inside a couple of laps.
The Tritec motor has a very strong bottom end.
In Italy
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 18th, 2007, 03:47 PM   #13 (permalink)
Ant FR
just to add to this, Peugeot Sport ( the racing arm of Peugeot) have been producing 270 bhp with this unit for nearly 2 yrs now, however it runs at such stupidly high temperatures i think they are not using it any more and are reverting to entering the Pug 207 into Super2000 spec running the more reliable 2 litre engine.
Old Dec 19th, 2007, 08:14 AM   #14 (permalink)
roland2003
Online
Interesting info ,thanks . This is one reason we have sold our R56,so we can concentrate on MORE R53 products. We will hold out until the higher power factory MCS turbo comes out and have another look at that.
Old Dec 22nd, 2007, 04:14 PM   #15 (permalink)
Hyper Active
Banned
Hyper Active's Avatar
So what do you believe the limitations of the R56 are, that make it unsuitable for GTT to tune it ?.
England Male View Hyper Active's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 24th, 2007, 12:29 PM   #16 (permalink)
roland2003
Online
Its certainly tunable , but until someone trys 400bhp through it ,it's unproven though. I think for the forseeable future R53 is the one to use for big power.
Two head units ? msaeger Interior & Ice 16 Mar 3rd, 2005 10:44 PM
Chrono Pak units? JoeDentist Interior & Ice 1 Nov 12th, 2004 12:34 PM
MP3 Head Units . . . bengascoyne Interior & Ice 7 Jul 22nd, 2004 03:55 PM
Head Units Mini Martyn Interior & Ice 7 Apr 23rd, 2004 02:35 PM
