| Tags: qanda |
| MINI2 Newbie | GTT ECU Re-maps Your going to have to excuse my ignorance on this one, i don't really understand the mini engine enough! BUt i have heard that the stock map on older cars with 163bhp is not the best for performance or economy, running very rich and with retarded timing. Therefore im looking to improve the fuel consumption and get a little more power, however im not keen on pulleys etc, so would a remap be my best option, if so how much is it likely to cost? Cheers |
| THE STICK Join Date: Feb 2003 Location: Worcestershire WR15 Local Time: 03:59 AM
Offline | The standard map is actually pretty reasonable compared to some other manufacturers factory tune maps. On the S a remap often does not add very much at all in fuel economy or power without having some other modifications with it. There are people who have found that a 15% pulley and a good performance panel filter colder spark plugs and a "good" re-map has improved economy, but this is borderline often. I have had 15% pulley and intake and manifold/ehaust etc and my economy remains around the same as it was when was stock car...thats means poor LOL |
| Back in a MINI Join Date: Jan 2004 Location: Hampshire Local Time: 03:59 AM
Offline | With modding, at the end of the day, that is all that matters! ![]() Everyone will have their own opinion, but as long as you're happy with your car, that's all that counts. ![]() |
| I miss my MINI | Opps, I just noticed that this was in the GTT thread! My bad.... On that, Roland does do great work and will look at your MINI and make recommendations on what would be the best route for you. Generally Roland leans towards not messing with the ECU and has done a great job with the MINIs he has turned out. You wouldn't do any wrong by having a chat with him about it. Global Moderator ![]() |
| | #6 (permalink) |
| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 03:59 AM
Offline | Hi James, the stock MCS will gain noticably more with a remap than with a 'pullied' MCS. Because the car is designed to run on very low octane petrol,as long as you are prepared to use super unleaded only, a remap with more ignition advance will produce more power. However a remap designed for stock pulley could not be used if you were to change the pulley later. |
| | #7 (permalink) |
| MINI2 Newbie | Yes i would be looking to run it on either Tesco 99 or Shell V Power, I figured the standard map is designed for hot temps with low octane petrol, hence the richness to stop pre ignition, is there anything else you would recommend changing with the remap, like spark plugs, panel filter etc? I will eventually go down the route of a pulley but that will probably not be for a year or so, i don't want to do too much in one go as i tend to get bored easily!! |
| Google maps! | Spottydog | General Discussion | 3 | Jul 13th, 2006 11:29 PM |
| ECU re-maps | ScottieCoop | Engine & Drivetrain Tuning | 1 | Jun 6th, 2006 08:39 AM |
| Run maps | larry paquette | Northern California Region | 5 | Feb 10th, 2006 11:44 PM |
| Ebay Re-Maps | smart | Engine & Drivetrain Tuning | 6 | Feb 1st, 2004 10:38 AM |
| DVD NAV unit maps. | ballerik | Interior & Ice | 9 | Oct 28th, 2003 02:08 PM |
