Visit Lohen!
Old Jan 18th, 2008, 06:34 AM   #1
GTT 280
The Power Cube
GTT 280's Avatar
Local Time: 07:40 AM
Question Pro-mapping
Hi Roland,
Any update on this ?
Cheers,
Karl.
Old Jan 18th, 2008, 06:51 AM   #2 (permalink)
Snowie
Snowie's Avatar
Local Time: 06:40 AM
Online
There are a few of us waiting for an update
Alan
In Italy
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 24th, 2008, 03:15 PM   #3 (permalink)
Rigsey
Alan
Me too
GTT, GRS, Janspeed, JCW, OMP + various other bits - 232.6bhp, 191.2lbft on 1320's rolling road
England Male View Rigsey's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 26th, 2008, 09:24 AM   #4 (permalink)
roland2003
MINI 2 Sponsor GT Tuning
Not yet guys, have to finish the Boot Brace and 280qs parts at present, but will be going by March with prices
Old Jan 26th, 2008, 09:50 AM   #5 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
no rush
Cheers,
K.
Old May 2nd, 2008, 03:10 PM   #6 (permalink)
Aberdeen Al
Aberdeen Al's Avatar
Online
Any movement on this?
Vroooom Vroooom
Old May 25th, 2008, 11:35 AM   #7 (permalink)
sillycar gt4cs
sillycar gt4cs's Avatar
bumpy time
Old Jun 10th, 2008, 07:56 AM   #8 (permalink)
roland2003
We have just completed GTT Pro Mapping on first customers car. ..more info in a couple of weeks.
Old Jun 11th, 2008, 02:01 PM   #9 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Benefit?
Interesting. Are you able to summarise the main differences between the current MTH map and this new approach?
Cheers,
K.
Old Jun 11th, 2008, 02:25 PM   #10 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
What sort of gains have you seen, and where have you seen them? I don't suppose you have any dyno sheets of before and after? Would be interested in seeing the differences, not just peak BHP, but the rest of the graph.
Does the remapped car have the bigger injectors and your adjustable fuel pressure rail? I though the rail means you could get the fueling correct without a remap.
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 11th, 2008, 02:26 PM   #11 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
Oh, and what was the price? Just noticed it missing. I suppose that says a lot about my priorities. Performance first, price second!
Old Jun 12th, 2008, 10:01 AM   #12 (permalink)
roland2003
Hi Guys, ok the first thing to stress here is ALL data/testing etc is completed on tarmac , NEVER a Rolling Road. Without wishing to repeat things too much, the RR cannot simulate 'real life' loads/cooling/airflow. If you tune for peak HP on a RR then it will certainly be compromised on the tarmac. In particular, timing may be too retarded and fuelling too lean.
We prefer to use the GTT 440cc injectors + GTT Adjustable Fuel Pressure Regulator as the optimum 'starting point' prior to any mapping , this gives linear fuel pressure V boost pressure even with increased boost (small pulley). . We use a fuel pressure guage to set this first.
Next we connect the wideband A/F meter and log the ratios at various rpm points and also in various gears (this changes load and airflow).
We then if necessary adjust the map to achieve target AF ratio based on this data.
Once correct we carry out other tests particularly high load tests to find the knock point,again this may enable timing to be advanced at certain points , or retarded at others. We can use knock meter,OBD2 data or ears to alert us of knock........Believe me ears going up a hill in 4th gear is by far the best method.
Of course we can use this oportunity to increase both rev limit and/or idle speed if required.
Its very important to have the right fuel in prior to the above (99 Ron), at will effect knock in particular quite alot.
Price......from £249+vat
This differs from mth mapping in that mth maps are optimised for any given list of products, our new system optimises for the entire package taking in even small variations between cars....but above all its all done on the road, which is where most people want it to be at its best.
We will not map for peak power ,a good sized reliability headroom buffer is always left in!
The Following 3 Users Say Thank You to roland2003 For This Useful Post:
Old Jun 12th, 2008, 10:11 AM   #13 (permalink)
Snowie
Snowie's Avatar
Online
At last some good news on the mapping front.
Will you also be able to 'soften' the traction control cut in effect - we have talked about this before as some of us do actually leave it on sometimes.
How long do you need the car for ??
Could be heading your way in late July to complete what we started last year.
In Italy
Old Jun 12th, 2008, 10:16 AM   #14 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
I cant say I am too interested in peak power, but the area under that.
If you ever get the chance, it would stil be great to see a before/after comparisons. ie. RR, data logging, 30-70 etc. I know that wont show drivability improvements, but should show performance.
Is the remapping done with DimSport equipment?
Are you able to lessen the effects of traction control? Always seems a bit on/off to me, even more so when you add more power to a MCS.
Old Jun 13th, 2008, 08:31 AM   #15 (permalink)
roland2003
Not sure on the traction control (I'll look into that). Yes butt dyno and stopwatch on the same car on the day on the same bit of tarmac in the same gear, between any 2 speed or rpm points is a very good test.......its actual driving afterll .
Old Jun 13th, 2008, 08:40 AM   #16 (permalink)
DaFlake
Dog Tired
DaFlake's Avatar
Local Time: 08:40 AM
Trimming DSC back was one of the perks of MTH. Worth doing if you can figure it out Roland.
Global Moderator
Old Jun 13th, 2008, 05:29 PM   #17 (permalink)
NeuroBeaker
PowerSteeringPumpActivist
NeuroBeaker's Avatar
Hey this stuff sounds pretty good! Is it a GTT in-house approach to remapping to solve the problem of MTH's business failing to turn around products in a timely and reliable fashion? Furthermore, will GTT pro-mapping be applicable to the R50 (ONE/Cooper), Roland? I'd be very interested indeed if it is...
Also, would this be a map you'd have to take a reading for and send off (relying on an external company for a quick turn-around), or can it all be accomplished by GTT within one day or one weekend?
As you know from our discussions when I last had my MINI with you, I'd love to get my ONE remap done by GTT but being based up in Glasgow makes it's quite difficult for me to get all the way down to Blandford on a regular basis. Therefore, it'd make the world of difference if this was a service that could be accomplished in one visit down ( ) rather than requiring two separate trips (something I might not be able to manage/afford).
Many thanks,
Andrew.
PS
The car is running absolutely fantastic after your service, Roland. Much appreciated!
NeuroBeaker
Proud owner of "Zeus" (a 'slightly modified' 2004 Mini ONE).
Scotland Male View NeuroBeaker's Indi Blue & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jun 16th, 2008, 05:40 PM   #18 (permalink)
munman_stk
Doktor Ayam
munman_stk's Avatar
Hi ppl. just got the car back from roland with the GTT pro-mapping on. the car is stinking fast now!! just like to say thanx to roland and john for all the work on the car. absolutely brilliant products and brilliant service.
btw, have been driving it hard to over the weekend to see the limits of the car and all is going smooth at the moment. only prob is the decat pipe...its a tad too loud. the car sounds like a scooby! im actually embarassed! no offence to scooby owners out there. im just getting funny stares from the folks here.
neurobreaker: as the mapping was done 'on-road', Roland had to keep the car a good couple of days to make sure the mapping was perfect for my set-up.
GTT260+
Brunei View munman_stk's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 17th, 2008, 09:43 PM   #19 (permalink)
Blown the doors off!
How long did the mapping take- What was the final cost>?
I may PM if req-
BTDO-
Old Jun 18th, 2008, 11:09 AM   #20 (permalink)
Aberdeen Al
Online
I may PM if req-
BTDO-
If it doesn't cause too much offence can you PM me total cost too?
Vroooom Vroooom
re mapping feedback philly c Engine & Drivetrain Tuning 8 Sep 1st, 2007 07:00 PM
CVT ECU Re-mapping Richard Morris Engine & Drivetrain Tuning 3 Jun 15th, 2006 08:38 AM
ECU mapping... Gary G Engine & Drivetrain Tuning 3 Apr 3rd, 2006 05:23 PM
RE Mapping supers Engine & Drivetrain Tuning 1 Aug 30th, 2004 12:49 PM
Re Mapping The Cvt Go Coop's MINI Cooper 5 Sep 12th, 2003 01:01 PM
