| MINI 2 Sponsor GT Tuning Join Date: Jan 2004 Local Time: 04:00 AM
Offline | Brand New GT Tuning 'MCS Oil Catch Tank'- preview Hi Guys,there is a brand new GTT 'Oil Catch Tank' for the MCS coming soon. It has 'left the drawing board' and production commences this week. Initial batch should be ready by the end of March. It incorporates many unique features which should put it way above current offerings. Rest assured it will not consist of a short length of silicon pipe with an alloy cap 'jubilee clipped on' at each end. I will put up the spec later on (no pics, as not made yet) Firstly though ,why do we need one? As standard the oily mist from the crankcase passes through a one way valve (PCV valve) positioned on the rocker cover via a part rubber & part plastic tube to a connection just upstream of the SC rotors. Inevitably not only are fumes & air passed through but oil; this is bad news for two reasons. Firstly it lines the intercooler and rubber bellows with oil reducing efficiency of the intercooler,which can make the bellows more prone to slipping off. Secondly ( and less widely known), most of this oil actually passes THROUGH the S/C and Intercooler ,into the engine & burns! This is far more detrimental to performance as the oil mixing with the fuel during combustion LOWERS THE OCTANE OF THE FUEL. This at best means ignition timing will be retarded to stop it knocking /pinking,(lowering power output in the process,) OR worse still,will induce knocking/pinking with possible long term engine damage . If you check your spark plugs (doing a proper plug chop),they should be a light to medium grey colour. If they are more 'biscuit' or tan brown colour,with 'deposits' ,this indicates burning oil. If the Intercooler has oil in it ,you can bet the oil originated from the breather system. Enter the GTT ' Oil Catch Tank'....... Regards Roland Gt Tuning ![]() |
| MINI2 Regular Join Date: Sep 2004 Location: Atlanta Local Time: 10:00 PM
Offline | Roland, I live in the US but would be very interested in a well engineered catch can. Two questions, will I be able to buy one of these to ship to the US, and could you PM me with more details? Thanks and good luck. |
Offline | GTT OIL CATCH TANK -SPEC. The unit consists of an aluminium body,of taller than usual dimensions to reduce emptying frequency. Rather than the usual 'sight glass' (sight plastic) which can both collapse & leak at the unions with the vacuum,we have incorporated a neat screw in level dipstick . It also has a drain plug positioned near the base. The top section bolts to the tank body & incorporates an O ring seal. Inside a supported baffle plate is positioned part way down with an aluminium delivery tube delivering all the oil BELOW the baffle,a stainless gauze is also used below the baffle to further assist with skimming off the oil.The exit pipe is flush with the top making it almost impossible for any oil mist to get out.The top,baffle and tube all come out as one,enabling easy cleaning plus the option of using stainless steel gauze below the baffle. The unit is positioned in the engine bay,and bolted to the chassis with an integral bracket. The OE earth lead is repositioned slightly.The unit has no visable welds and is hand mirror polished.All fixings and pipework is included. We believe no other design will remove (catch) the oil more effectivly nor be more user friendly/reliable. The GTT build & finish speaks for itself. Price TBA REgards Roland Gt Tuning ![]() Last edited by roland2003 : Mar 5th, 2005 at 11:21 AM. |
| | #7 (permalink) |
Offline | After some final thought ,we have decided not to use a plastic 'sight glass' (as on other makes) to monitor oil level. This is due to reports on others of the sight tube sucking in /discolouring/ or leaking 'sight glass' unions; caused by the negative pressures inside the catch tank. Instead it will feature a Screw-In Dipstick to check the oil level - How Cool Is That!! Regards Roland Gt Tuning |
| | #9 (permalink) |
| MINI2 Irregular | If this is occurring and/or has already happened in our MCSs, does installing the oil catch can reverse this, as well as prevent it from occurring? It sounds like only those with the newest cars would benefit the most from this, because they have not reached the stage mentioned above. |
| | #11 (permalink) |
Offline | Whilst fitting the Catch Tank it would be worth removing the Intercooler and bellows where the oil collects to clean the oil away using say brake cleaner & an airline. Once done hopefully no more (or at least considerably less) oil will get through. Regards Roland GT Tuning ![]() |
| | #13 (permalink) |
![]() Taller Than You! | Any updates on the catch can roland? Is it similar to the alta solution?http://www.altaminiperformance.com/p.../CATCHCAN.html |
| | #20 (permalink) |
Offline | Hi Guys, yes sorry for the delay on this one,we are cutting metal as we speak so wont be too long now . Price is £85+vat. They will be available direct from GTTuning Regards Roland Gt Tuning ![]() |
| GT Tuning Oil Catch Can - First Pics! | roland2003 | Engine & Drivetrain Tuning | 53 | Aug 15th, 2007 12:40 PM |
| Brand New GTT MCS Header Tank +pics ! | roland2003 | GT Tuning | 7 | Apr 7th, 2007 11:58 AM |
| Oil Catch | MiniBimmer | Engine & Drivetrain Tuning | 12 | Jul 24th, 2006 11:04 PM |
| Oil catch can | MiniFr34k | Engine & Drivetrain Tuning | 11 | Aug 2nd, 2005 05:42 PM |
| Alta Oil Catch Can (Red) Brand New | enzothemaddog | For Sale | 1 | Sep 25th, 2004 08:51 AM |
