| MINI2 Newbie Join Date: Mar 2005 Local Time: 04:15 AM
Offline | Sirius Factory OEM install on '05 MC Cabrio I received a factory Sirius unit for my 2005 Cabrio with the H/K radio.I purchased the Mini SIRIUS Satellite Receiver - Item # 84 11 0 150 535 and the Mini SIRIUS Satellite Radio Install Kit - Item # 84 11 0 150 534. I did not need the extension cable that is recommended for the H/K system. I received the factory install directions from MINI and was told that they were the same for the MC and the MC Cabrio. THEY ARE NOT! There is nowhere to mount the unit behind the panels in the trunk as recommended in the directions. The pillars from the rollbar are in the way. Even though the backet does not fit in the right spot it does make the install easier. I also used the Terk Mini antenna SIR-MINI with Terk Sirius Satellite Radio Splitter and Adapter SIR-SP.First you need to find the wire harness behind the right trunk panel. There is no access panel. Remove the black bolt and lift the bottom of the panel to get the harness. Once the unit was plugged in the radio did recognize the Sirius unit. I mounted the unit in the trunk on a carpeted board attached to the rollbar pillar. It is visible but does not take up much room in the trunk and looks good ( I plan on painting the unit black to make it less visible For the antenna, I ran the wire to the front of the car and mounted it next to the factory antenna(It is small enough that it does not look bad). I wish Mini would make a Cabrio antenna but this works well.. I will add pictures soon Last edited by mia mini : Jan 14th, 2006 at 05:31 PM. |
| MINI2 Newbie Join Date: Apr 2005 Local Time: 11:15 PM
Offline | Mia Mini - Did you just install the sirius receiver box and the sirius antenna? I am curious if a standard sirius antenna will work. I currently use a PnP sirius unit and have the antenna on the dash up by the windshield...no probs with reception and looks good. |
| MINI2 Master | Which black bolt do you mean? Harry MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| | #6 (permalink) |
Offline | There is no factory antenna for the MC Cabrio I used the Terk Sirius antenna and mounted it next to the factory antenna It is small enough that it does not look bad When they come out with a factory antenna I will trade it out |
| | #7 (permalink) |
Offline | Harry If you look in the trunk the side panels are screwed to the rollbar pillars by a small black plastic screw When you remove that you can pull the bottom of the panel up to get to the factory wire harness I will try and post some photo links |
| | #8 (permalink) |
Offline | Here are some photo links of the install Again I am planning on painting the gray unit black this weekend and when they get a factory antenna I will swap it out http://www.northamericanmotoring.com...SCN0450_2_.JPG http://www.northamericanmotoring.com...SCN0446_2_.JPG |
| | #10 (permalink) |
Offline | Yes I channeled it under the rubber seal It lifts up with gentle pressure and the wire fits nicely under it The bend from the roof to the side pillar took some time but you cannot see the wire I ran it back lifted the back seat and fed it through to the trunk and plugged it into the unit |
| 2005 OEM Sirius Unit NOW Available!!! NOT!!! OOPS! | Cooper76 | Interior & Ice | 5 | Feb 4th, 2005 01:30 AM |
| OEM or aftermarket alarm for cabrio? | 2phun | General Discussion | 14 | Nov 23rd, 2004 08:45 PM |
| XM Direct using OEM Sirius antenna? | Thor Sanchez | Interior & Ice | 2 | Sep 18th, 2004 07:06 PM |
| OEM Sirius for 2005 MCS | kfmuller | Interior & Ice | 4 | Sep 14th, 2004 12:42 AM |
| info for getting Sirius via aftermarket w/ OEM antenna | Galvatron | Interior & Ice | 0 | Jun 17th, 2003 08:51 AM |
