Visit Out Motoring!
Old Feb 6th, 2006, 10:45 AM   #1
Ade1986
Ade1986's Avatar
Local Time: 12:15 AM
Pioneer x1 installation
Theres a few threads on here but a few are american etc, i want to install an x1 in my 51 plate Mini Cooper.
I know ill need the Radio fitting kit from Mikey (iso leads, radio antenna adaptor etc)
From what i understand, you put the headunit in as any other headunit, there are then cables that run to a hideaway unit. Ive heard a good place is under a front seat, which ones best/easiest? How do i route the wires there?
I then beleive you have to link it to a speed pulse wire, which i thinks on the drivers side sill? and the reverse wire? and the handbrake wire? Then you have to place the GPS antenna, ive read under the dash is a place. Then thats it......what i really want to know is, is it tricky running wires to all these places?
Sorry for the long post. I have installed head units, amps, speakers in previous cars but navigation is new to me...
Old Feb 7th, 2006, 06:56 PM   #2 (permalink)
mikeythemini
I can't get no sleep
mikeythemini's Avatar
For ease of lifting the carpet the left side underseat is the place, BUT then the speed pulse has to run all the way round to the other side.
So then you could fit it under the right seat, you cant lift the carpet as high but you will still get the box in. Then get the speed pulse easy & you can actually get the reverse wire on the right side too
BEware - dont switch the key on whilst the seat is disconnected - so reconnect before you try to test your new nav.
If you are fitting the hideaway under the carpet under seat then remove the foam from the underside of the carpet so the box can breath & doesnt overheat.
Oh and yes the gps can go under the dashtop
Old Feb 15th, 2006, 07:32 PM   #3 (permalink)
Ade1986
Ade1986's Avatar
Right ordered my fitting kit yesterday from Newministuff (Cheers), should be installing on Saturday. Would it be a help to anyone if i took pictures throughout and write about how i fitted it?
Old Feb 19th, 2006, 04:08 PM   #4 (permalink)
Ade1986
Ade1986's Avatar
Its installed now....
I connected the speed pulse but it doesnt seem to be picking anything up from it. The connect i used was on the drivers side and had two wires going into it both green/yellow, would it make a diffierence if i chose one from the other, i could test the wire on installation due to the passenger seat being out and would have set the airbag light off.
Any ideas?
Also did the same with the reverse wire, as there were a lot of blue/yellow wires going into that connector i was unsure which one to chose, but i dont know if i have chosen the right one either?
Pioneer X1 s123kev Interior & Ice 5 Mar 1st, 2005 08:29 AM
Pioneer DEH8450MP leon1982 Interior & Ice 5 Dec 25th, 2003 06:41 AM
Pioneer Speakers or not Pioneer Speakers?? scott321172 Interior & Ice 1 Oct 1st, 2003 09:13 PM
Pioneer Stereo xnetco Interior & Ice 0 Nov 21st, 2002 04:54 PM
Pioneer HU BRGMINI Interior & Ice 3 Jul 1st, 2002 05:03 PM
