Carccessory.com
Old Jul 21st, 2002, 09:01 PM   #1
Technomage
CVT is gone, S hole now..
Technomage's Avatar
Local Time: 07:32 PM
Send a message via AIM to Technomage
Question how to power stuff in the boot?
If I had a device that needed 12 VDC @110mA and it was in the boot how would I power it safely? As in not drain the batteries, the device is an 'always on' device. It will be mounted either on the hatchback or if thats to difficult in the bumper where the park distance would be.
Basicly I am working to get the AUX video working on the Navi System and have a reverse camera.
Kind of like navtv.com has but cheaper.
I am a novice at this so be gental.
Thanks,
Technomage
-Technomage
turned due to CVT problems
Now Stylein in
MCS CR/W All options except NAV and PDC. Garmin 2610 NAV.
My MINI Adventure so far: http://www.bradherman.net/MINI
United States View Technomage's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 21st, 2002, 09:06 PM   #2 (permalink)
bg MINI
Local Time: 09:32 PM
Does the power port in the trunk work?
There is supposed to be a power port in the hatchback.
Open it up, look to the left (black cover) and pull it off.
Should reveal a power port.
I hope that helps.
Old Jul 21st, 2002, 09:30 PM   #3 (permalink)
BruceK
Moderator & Sponsor
BruceK's Avatar
Local Time: 08:32 PM
"Always on" may not be compatible with the MINI's ECU.
If I remember correctly, on some of the early MINI's in the UK, there was a problem wiht the audio unit apparently not shutting itself off, causing the ECU to constantly be woken up. Which in turn caused the battery to become dead (go flat).
You may want to do a Search on 'battery' to learn more.
Old Jul 21st, 2002, 09:50 PM   #4 (permalink)
Technomage
Technomage's Avatar
So how are dose everyone power there giant ICE Installs? Those huge systems in the back have to draw power from somewhere?
Are they taping into the wireing harness?
-Technomage
Now Stylein in
Old Jul 22nd, 2002, 06:20 AM   #5 (permalink)
Dom
Test thread infiltrator
Dom's Avatar
Local Time: 03:32 AM
Send a message via MSN to Dom
No, we run a wire from the battery into the boot, under the upholstery and everything. This is much easier the in 'S'...
It seems that whilst your requirements don't take much power, the rear power socket is only on with the ignition. Ignition 1 I think.
Running a power cable through the car:
http://www.mini2.com/forum/showthrea...&threadid=3723
Obviously, you may not need such a meaty cable
Hope that helps,
Dom
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 22nd, 2002, 08:04 AM   #6 (permalink)
GaryM
GaryM's Avatar
Send a message via Skype™ to GaryM
Putting Two and Two together, if it is the CCD camera for reversing why not wire it in parallel to the reversing light!
Does it need to powered all of the time? If it does then you have to accept that if the car is left for a long period, say at an airport the battery may go flat, eg: like any system with a car alarm.
Depending on how complex you wanted to get you could have a small 12V battery in the rear that is kept charged while the car is running and then used to power the kit. So if it's battery goes flat it won't harm the car.
Sourcing Stuff in Canada - Power Take Off StormTide Canada 2 Dec 18th, 2006 07:39 PM
Boot Power Socket Trophy160 MINI Cooper 25 Jul 12th, 2004 06:20 PM
Black Roof White Stuff on hinge and Boot area Gridwench General Discussion 2 Mar 19th, 2004 03:07 AM
Power supply in boot Big Dave MINI Cooper S 3 Jan 24th, 2003 10:48 AM
