| MINI2 Senior Join Date: Nov 2005 Location: Oxford Local Time: 01:54 AM
Offline | Anyone fitted Genesis 6x9 subs in a Mini? Looks like I'm getting some Genny 6x9 subs for my car, does anyone have any tips about fitting them and getting them sounding good? I'm told you have to heavily deaden the inner panels and in an ideal world seal off some gaps with expanding foam. I assume the dis-assembly procedure for the car is the same for all years of Mini (mine is a late 05 build) and it's just the deadening and sealing that might be tricky. Is there space for an MDF spacer between the metalwork and the speaker to give a more rigid mounting point? Cheers! |
| MINI2 Regular | hi there. having replaced many a quarter panel on a mini here are my suggestions: the speaker is mounted onto the inner quarter panel with 7mm screws, and the mounting is quite rigid, so mdf rings are probally not needed. when you have removed the speaker, what you can feel behind is the actual body panel. i would recomend usind some dynamat or the equivelent to reduce vibrations but apply carefully as you don't want to put high spots in / or damage the paint on your bodywork. it might be an idea to also run a small strip of sealer/double sided foam stuff (like what holds badges on) around the edge of the mounting hole to make sure you do not get any vibrations. hope this helps |
| Genesis Profile 69 Subs - but what amp? | detchibe | Interior & Ice | 1 | Sep 19th, 2007 12:03 PM |
| Genesis 6x9 magazine review. | SteveM3 | Interior & Ice | 1 | Jun 26th, 2004 06:25 PM |
| Genesis 6x9 magazine review. | SteveM3 | Interior & Ice | 0 | Jun 26th, 2004 08:59 AM |
| Genesis 6x9 subs the report | LOUD little MINI | Interior & Ice | 19 | Oct 2nd, 2003 03:55 PM |
| Genesis 6x9 subs. | LOUD little MINI | Interior & Ice | 15 | May 12th, 2003 06:59 PM |
