| MINI2 Newbie Join Date: Mar 2006 Local Time: 07:05 PM
Offline | Steering Wheel - Question...? I have a Sept 2002 MCS and it has a two spoke multi-functional steering wheel. I have noticed that the new mini's have a three spoke design which is slightly smaller, which I prefer. Is it possible to swap between the two ?, has any one done this before ? Cheers !! |
| Loving It! | Hi, Check the link below. http://www.mini2.com/forum/interior-...steering+wheel Hope this give you a little help in to what your after ![]() . . : Atif : . . |
| MINI2 Newbie Join Date: Nov 2003 Location: Essex Local Time: 08:05 PM
Offline | Hi, Just upgraded my 2 spoke Multi Function Steering wheel to a JCW 3 spoke MF wheel. So for that age of car (53 reg) it works fine - I presume this will be the same for a 52 reg car. All the controls function perfectly. Apart from the disconnecting the airbag its a hassle free swap. I did the work with the battery disconnected which i have been told eliminates the risk of the airbag warning light latching on, or any nasty explosions........ You'll need a new steering wheel, airbag, MF switches, steering wheel loom and a couple of screws. bit pricy but the JCW wheel is superb. Hope this helps anyone else thinking of a swap. |
| MINI2 Master Join Date: Dec 2002 Location: Malmesbury, Wilts Local Time: 08:05 PM
Offline | Yep that is helpful thanks. A picture or two would be even better .![]() Some people are like a Slinky ........ not really good for anything, but you still can't help but smile when you shove them down the stairs |
| | #7 (permalink) |
Offline | Hi, sorry don’t have the receipt to hand but approximately… • 3 spoke wheel airbag around £100 via EBay (a risk, but cheaper than the dealers) • JCW Alcantara & Leather steering wheel aprox £240 from the dealer • MF switches and lower spoke cover & securing screws aprox £120 (or source from EBay via a second hand 3 spoke MF wheel) • Steering wheel Wiring loom aprox £10 Its not a cheap upgrade, but its possible to sell the old 2 spoke and airbag to recover some costs. The JCW steering wheel is absolutely superb & worth every penny. Make sure you can live with the new button layout though as some people don’t like it. The wheel seems to be a bit smaller in diameter than the 2 spoke & the rim is a bit thicker. It also has what appears to be foam backed Alcantara / Leather, so it's a slightly soft feel. I had to ask 4 dealers before anyone would admit that its possible. Can see any reason why they would not want to do the upgrade though a its all standard parts. Sorry, forgot to take any pics during the install, but its quite straightforward. All I did was…… • Park the car with the steering wheel straight ahead • Keys out of the ignition then disconnect the battery. (So it's impossible to turn the ignition on and latch the airbag light) Remember the boot will lock when shut so leave it open so you can re access the battery later on. • Remove the 2 spoke wheel airbag by unscrewing the 2 Torx bolts located in holes on the rear face of the steering wheel. (Near the radio controls) • Pull the airbag off the wheel. & remove the 2 electrical connectors on the back of the airbag (they are locked down via a small latch, if you look at the green connector, it’s the black piece of plastic, just gently prise it up and repeat for the black connector) • Put the airbag somewhere safe, being careful not to scratch the front. I also put some electricians tape over the contacts on the back of the bag to protect them from damage / static. • Loosen the centre nut holding the steering wheel (but don’t completely remove it yet), then pull the wheel towards you, mine was not tight on the spline. If you do have to knock it loose the nut will stop it hitting you in the face. • Disconnect the electrical multiplugs from the slipper ring at the 12:00 O'clock position - they are for the horn and the other buttons. • Remove the nut, but before removing the wheel, check the position on the spline, it's fairly obvious at the 6:00 o'clock position there's a marker to show where the wheel lines up. • Put the new steering wheel on so the marker lines up and it's straight. • Install the lower wheel spoke cover, loom and multi function switches (secure with screws from behind) and route the wiring loom along the top of the wheel in the channel. • Plug the multiplugs for the horn and MF switches into the slipper ring connector. • Tighten the steering wheel centre nut to 63 NM. • Connect the new airbag to the existing wires and press down the securing latches. They are colour coded so make sure green connector goes in the green socket. • Quick visual check that all wires are tidy and connectors secure • Press the airbag firmly onto the wheel, it seems only to secure via 2 latches. The dealer says no bolts for this one. If you have to remove there are 2 holes in the steering wheel that you have to press through to release the latches inside the wheel its self. • Reconnect the battery and check all buttons & Horn work OK. It takes about an hour if you take your time. I have done this twice now and haven't had any problems with the airbag light or any airbag detonations….. Hopefully this all makes sense - Any questions, feel free to drop me a line. |
| | #8 (permalink) |
| MINI2 Senior Join Date: Mar 2005 Location: Nailsea Local Time: 07:05 PM
Offline | Thanks for the info, I have a 3 spoke MFSW to go on my car and currently have a non 3 spoke MFSW fitted! I took the old one off the other day and found the slipper ring to be totally different i.e nowhere to plug the mfsw controls into, so re-fitted the old wheel! I found the no of the new slipper ring but do you or anyone know if i need an additional loom and some kind of coding from bimmer to make it work? Thanks in advance, Rick. |
| | #9 (permalink) |
Offline | Hi, There is a retro fit kit available for the 2 spoke wheel MF wheel and i believe the 3 spoke, however its very expensive especially at dealer hourly rates. Take a look at the following..... http://motoringfile.com/howto/MFSW.PDF there are a few threads on Mini2 that will will give you all the info. |
| | #12 (permalink) |
Offline | no problem, the only other point i would add is to wait for 10 mins after disconnecting the battery before pulling the airbag as it will help discharge any capacitors in the system. drop me a line if you get stuck. |
| | #15 (permalink) |
| MINI2 Regular | hi i am curently doing a 2 spoke to three spoke conversion however i am missing the bracket that holds the air bag in place does anyone know what part number this is or where i can get one cokermoto@googlemail.com |
| JCW steering wheel question | DHA | 2nd Gen Interior & Ice | 4 | Oct 2nd, 2007 10:51 PM |
| Urgent!!! Steering Wheel Pump Question | KMK163 | Faults & Fixes | 2 | Apr 13th, 2007 06:10 AM |
| Another retrofit Steering wheel question | CoolCarStuff | Interior & Ice | 4 | Sep 22nd, 2006 10:57 AM |
| Multi Function Steering Wheel Question ????????????? | Jacked up | Interior & Ice | 17 | Jun 26th, 2006 12:13 PM |
| Multi.Function Steering Wheel Question | FREEZE BOX | Interior & Ice | 5 | Jun 23rd, 2003 02:23 AM |
